um, i found this on the uci site:
4.1.042 As far as possible, the course for cross-country, four cross and downhill events must be totally separate from that of all other events organised on the same site. If this is not the case, the training and race timetable must be drawn up so that the courses cannot be used simultaneously.
So i'm just thinking aloud here,
I was under the impression that the 4x and dh HAD to finish at the same spot, i certainly recall at the rotorua worlds there was a 15min walk between finish line of the 2 tracks. And had assumed they had gotten permission for this due to the various owners of the land.
So if this is correct there is no rule about not being able to have a seperate finish line for the Dh?.
So previously to finding this i was under the impression the combined finishes was a fact of life, if the above is correct then that isn't the case,unless of course there is a special World champs rule?, even then rotorua was allowed to have seperate finishes so a precedent has been set.
So say for arguments sake the Dh was made a little slower up around the top section then it could theoretically have a temporary finish at the 4x mound? and still come within the time restrictions, and remove the section creating the most controversy.
Certainly should be alot cheaper than getting the diggers in to enlarge the finish, which i would assume would still need the controversial long pedally bit to get to.
thoughts anyone?
