I'd be looking for a few washers to fit around the axle so the sleeve has even pressure all the way around, not just at either side where the jaws touch. Might be ok if it frees up easy, but you don't want jaw marks all over the end of the sleeve.Use penetrant like CRC penetr8 or Maxima MPPL.
Then use vice to act as a platform for the outer sleeve, ie don't grip the axle, just close the jaws enough that the sleeve rests on them. Then tap with rubber mallet or soft face hammer.
Im using diesel right nowA 50/50 mix of acetone and automatic transmission dexron3 is a lot better then any off the shelf penetrating fluids you can buy. Put in a sealed container with the part. Fumes are toxic
Oh, yes please, the bigger the better.It's time for the hammer.
It needs more than a tap matwhold the axle sleeve in one hand and belt the axle with a block of wood or similar with the other
you are trying to 'shock' the axle from the sleeve, not belt the living piss out of it by mangling it with a lump hammer in a vise..
Oh sorry i read it. Its bloody stuck tho its a painwhere did I say tap!
Not a stupid question and no its notstupid question, but is it bent?
even slightly bent, and she aint coming out!
Worth a crack sounds decent damage wise as in it is unlikely to damage too muchGot access to a big bench vice, like with 200mm opening between the jaws? Block of hardwood about 50mm thick, drill a 12mm hole through it, put it on one end of the axle, put the whole lot in the vice and wind it up slowly until you get it moving. Swap wood to opposite end several times if need be to work it loose so you can pull it out.
I like this idea, but I suspect a big ass washer with a 12mm id would help.Got access to a big bench vice, like with 200mm opening between the jaws? Block of hardwood about 50mm thick, drill a 12mm hole through it, put it on one end of the axle, put the whole lot in the vice and wind it up slowly until you get it moving. Swap wood to opposite end several times if need be to work it loose so you can pull it out.
