What are they?
Gamuk Bikes.
Bikes - Gamux
Bikes Swiss precision for the ride of Your Life.Epic? Let’s start there. THE SEGO 200mm – Downhill Race Bike LEARN MORE
What are they?
That dh bike looks a bit like a BMW, which is hawt!Gamuk Bikes.
Bikes - Gamux
Bikes Swiss precision for the ride of Your Life.Epic? Let’s start there. THE SEGO 200mm – Downhill Race Bike LEARN MOREwww.gamuxbikes.com
From the brief fireroad spin I had on your Katipo, shifting under load seemed like a non-issue. How do you find it on the trails?Will be interesting to see if it can be retrofitted to existing gearboxes and if it shifts better under load, which is what a lot of people complain about with the current grip shift...
Still, very occasionally, I might get slightly stuck on going to the easier gear, either between 9-8 or 5-4, but that's a rarity now and easily sorted when I wake back up again.From the brief fireroad spin I had on your Katipo, shifting under load seemed like a non-issue. How do you find it on the trails?
new gearbox bike!!!
I was emailing some companies in 2008 gathering stp files for a frame I was designing.
Ive got Karl Nicolai's email address if you want to see if that still works
Also, feel free to e-mail Nicolai and ask them if they're going to make a Saturn 16 GPI. When I asked the response was underwhelming to say the least...
Yep. That's tied to their original gearbox. No Pinion able to be fitted to that one.I've got no experience other than a little window shopping, but I reckon Cavalerie out of France look pretty tasty. They use Effigear though...
They look nice, but I sure as hell wouldn't be keen on pedalling a bike that actually forces the linkage to compress with every pedal stroke. (Chainstay pivot is concentric to the output gear, so no chain force to be had via an off-set pivot around the chainline onto the top of the chainring).I've got no experience other than a little window shopping, but I reckon Cavalerie out of France look pretty tasty. They use Effigear though...
Drat... (from 7m54s)Will be interesting to see if it can be retrofitted to existing gearboxes...
Remedy | Remedy | VHPG MX | VHPG MX | |
150mm | 160mm | 160mm | 170mm | |
Actual Frame Size | M 17.5" | M 17.5" | M | L |
Geometry Position | Low | High | ||
(A)Seat tube | 41.9cm | 41.9cm | 420mm | 450mm |
(B) Seat tube angle | 68.0 ° | 68.5 ° | ||
Effective STA | 74.2 ° | 74.7 ° | 77.5 ° | 77.5 ° |
(C) Head tube length | 10.0cm | 10.0cm | 110mm | 110mm |
(D) Head angle | 65.6 ° | 66.1 ° | 64.0 ° | 64.0 ° |
(E) Effective top tube | 58.8cm | 58.6cm | 598mm | 618mm |
(F) Bottom bracket height | 34.9cm | 35.6cm | 343mm | 343mm |
(G) Bottom bracket drop | 1.6cm | 0.94cm | 34mm | 34mm |
(H) Chainstay length | 43.5cm | 43.3cm | 419mm | 419mm |
(I) Offset | 4.6cm | 4.6cm | ||
(J) Trail | 11.5cm | 11.2cm | ||
(K) Wheelbase | 116.7cm | 116.6cm | 1223mm | 1243mm |
(L) Standover | 76.6cm | 77.1cm | ||
(M) Frame reach | 42.0cm | 42.6cm | 460mm | 480mm |
(N) Frame stack | 59.2cm | 58.8cm | 639mm | 639mm |
brake routing on the chainstay doesn’t work well with Shimano 4 pot brakes, although I think this has been updated since I got the frame. Adjustable seat stays have come out now I think.@yuley95 @frenchman and any other Kavenz owners out there how is the pedal bob if you're in roughly a 1:1 gearing? Any other idiosyncrasies I should be wary of?
I’m running an EXT coil and not bothering using the climb switch because pedal bob is not an issue. This is in climbing gear for me so not 1:1 (more like 3:5). I dont think it would change too much though.@yuley95 @frenchman and any other Kavenz owners out there how is the pedal bob if you're in roughly a 1:1 gearing? Any other idiosyncrasies I should be wary of?
