fatnold
Being an ex-roadie I have over 250,000km in the last 6 years
But not once did you exagerate wildly.
I think you should get some hard and fast numbers before speculating on strength of the chain. Except when shifting and cross chaining, Almost all of the load of a chain is taken up with the side plates and mostly in tension. While the chain itself is thinner, most of that will be in the actual pins and rollers, the difference of which contribute didly to the strength.
Admittedly you could use the same technology and make a kick arse 8speed group set, but not sure you'd want to...
I for one am craving closer ratios and more gears in a mountain bike.
With the exception of Ed and maybe Joel here, Saying you don't "need" more gears is maybe a little hypocritical. if you've ever used your 22:32 (or 22:34 for that matter), then clearly you're using more gears than 8speed already!
More torque through the hub? only if the ratio is lower than what you have already, which it isn't.
A couple of people here have already said that's exactly what they'd love to see. The greater durability, greater tolerances are just what I want. Shimano - if you're listening; SRAM's 2:1 actuation ratio is nice. Have you thought about 3:1?
Plate strength is also important. I bend plates on an occaisonal basis, due to some habits picked up SSing. (Pedalling backwards when cornering to move my feet for balance, when my chain has jumped on the cassette due to bumps. It twists the chain as it enters rear derailleur.) I don't want thinner plates.
I'd suggest this puts you in with a very small minority of riders. Before 2010, exactly who was screaming out for closer ratios on their MTB? Like, 0.001% of people who already had got themselves sorted by using an Ultegra 12-27 9-speed cassette cause that kind of rider don't even come close to needing anything as low as 22-27 anyway.
Don't confuse the number of gears available with a high or lowest possible ratio.
Oh .. then why did Shimano release the FH-M529? (Hint: It was 29er riders using 36t cassettes repeatedly killing their regular hubs.)
Torque = Force * Distance. If there are more teeth on the cassette, the torque is greater because the force is at a greater distance from the hub. If I'm not mistaken, there is actually higher tension in the chain with more teeth on the front, not less.
If I was running 26-39 or whatever up front, I think I'd be shifting up front a lot more, and shifting up front is a lot less pleasant than at the back. It's better to avoid it where possible.
Sure, I might be "whinging about losing compatibility with my existing gear." I think it's very much worthwhile to keep compatibility. We've had half-inch pitch on chains for decades .. cause it works. We quickly went from 6 to 9 speed in the 90s .. and 9-speed has stayed with us for a decade because it works well. I still think the cons outweigh the pros.
XT came in 11-30 flavour.Find me an 8speed casette that has a) decent shifting and b) decent mechanical range. As far as I'm aware, the MTB varieties ended at 28t
I am willing to be corrected here ('cause lets face it, 1st year physics was over 10 years ago) but I'm pretty sure Torque at the axle is a factor of the mechanical advantage being applied regardless of the size of the cogs. 29ers are a special case because a) the resisting torque is higher to start with and b) people are running 22:36 which means the mechanical advantage is higher. you're using a corner case without sufficient science to justify your reasoning. But Like I said, I'm willing to stand corrected... "show me the numbers son"
I havn't bent a plate on a chain ever...
I'm not. Find me an 8speed casette that has a) decent shifting and b) decent mechanical range. As far as I'm aware, the MTB varieties ended at 28t.
Have you tried the new SRAM front shifting? or perhaps if you only ever use your front 32, a nice 10speed spread out the back with 32:36 1x10 would be sweet...
Yes, you're correct - you'd need an overall lower ratio, (IE by using a 22t) to apply more torque. 29ers are doing it though, so I wouldn't call it a corner case.
I use my front shifter - just as little as possible. Front shifting will never be as good as the rear, because of the bigger ratio and teeth count involved.
I still think the great majority of riders benefit more from better tolerance, wider range, higher strength and reliability of the lesser-speed systems VS the closer ratios of 10-speed.
How is that unique to the new SRAM 10 speed group sets?
while you are probably right, SRAM are claiming a "significant improvement" with their 2x cransets and that whole 1.5ratio thing. I think you would have to try it before saying that it's not practical or not efficient enough to do on a regular basis. Besides, they have triples as well, and you can chose a crank set that best matches your desire ratio levels. Personally I switch between big and middle a lot. It's common practice to put it in the dog on downhills to improve chain slack issues. Doesn't everyone?
Again I fail to see how this is an issue with 10 speed group sets? Perhaps your preference for crankset ratios arn't entirely met, but I'd dare say you'd be the exception than the rule. Besides, with 2x10 we've already established you can use the entire cassette width in either gear. Doesn't that mean less changing on the front?
Err wider range? didn't we just go over that's why we have 10speed? Reliability? of what? you're expecting the new groupset to spontaneously fail? how is that any different to any other new groupset?
I think your only claim you can make with any facts behind you (apart from chain strength, which I'll go into in a bit) is the tighter tolerances. So I started thinking about that too...
According to the Late Sheldon Brown, there's a 4.8mm spacing difference in the 8speed cogs, vs 4.34 for 9 speed and 3.95 for 10speed. Assuming you have to be over half way to shift then that means there's less than 10% tolerance difference between 8speed and 9, and similarily for 9 and 10. Divide that by two (for either side of the sprocket) and we're talking a +/- 0.4mm tolerance difference at the deraileur. In reality, the difference is probably less because well... the chains are a different thickness as well
(ed: I checked chain widths, and the loss in tolerance is still +/- 0.4mm)
In terms of cable pull that equates to:
Shimano (1.7:1): ~.24mm at the shifter
SRAM old (1.1:1): ~0.4mm at the shifter. possibly more noticable
SRAM XX (1.3:1): ~0.3mm at the shifter.
Assuming that the chain thickness differences reduce this a little, the tolerance differences here between it being one gear or the other are SFA between 8 an 10, though admittedly on "old" SRAM shifter you'd probably notice the difference in terms of making the cable up, between 9 and 10, I'd be surprised if you noticed the difference. That's +/-10% difference in tolerance between 8 and 10.
What would be of interest is to play with your 9spd drive train and see what .4mm of cable pull does. Would you really notice it in real life? or are we really talking peas and matresses here?
So on the chain strength front, I couldn't find any numbers of repute in my google search, but Wipperman claim their 9speed chains are as strong as their 8spd chains, despite "less metal". 10 speed chains do have less thickness in the plates but it's load spread across the surface of the plate. I don't know enough about material phsysics to figure out what the difference is (has more to do about cross sectional area I think. There are claims that other manufacturers have 10speed chains as strong as their 9speed. Wipperman is not one of those. From what I can make out, the rest of the kit (teeth etc..) are the same. in terms of width (2.2mm) so yes the chain will be weaker, may stretch easier, but wear well... we'll see really.
So after all that, we can say that:
* Depending on what your option you chose you get either more usable gears, closer ratios or wider spreads. We've already established for 99% of mountain bikers, one of these options is desirable
* The groupset as a whole is lighter
* the difference in tolerance is +/- 10% over 10speed or about 5% over 9spd Fractions of a mm loss in tolerance. Enough to notice?
* "increased torque" on the hub is either a furffy, or not unique to 10spd depending on what you're talking about
* Yes chain strength will probably be reduced but not sure by how much and if it'd be an issue. Effects on Wear and tear is yet to be defined.
* The 2x gives you better front shifting with the 1.5 ratio
...I'm sorry, what was the problem with the new groupsets?
*shrug*
Cheers
Spoonie
Good to see no one is taking this too seriously....slow day at work?![]()
Bullsh!t pull your head out of your a$$ that is the biggest load of cr@p I have seen on here.
Being an ex-roadie I have over 250,000km in the last 6 years on 10spd and I know (and am not speculating as I do all my own maintenance) that the wear and tear is no higher then 9spd.
So.... does anyone have the inside scoop on when 2x10 X0 or X9 will be available in Oz? Keen to spec it on a new ride but not sure if it's weeks or months away.
Cheers
Not sure they are...
If you got to SRAMS 2x10 website they are only promoting XX & X7. There was mention earlier this year of X0 and X9 being 10spd but whether they are who knows.
