HamboCairns
Thanks for all the bananas
Doesn't it help you with maintenance and removing the wheel?I am with the comments on Instagram what the F does this even do that is useful.
Copies the SRAM cage lock function. So can lock it in a forward position for easier wheel removal or linking a chain together.I am with the comments on Instagram what the F does this even do that is useful.
Exactly. SRAMs had it for about 10 years. (Maybe they had a patent that ran out?)Copies the SRAM cage lock function
I gotta be honest, didn't think I'd miss the cage lock much moving to Shimano after 8 years. First rear wheel removal made me look like I'd never done it before. Given it's the only thing I miss from SRAM, I think I'll be $50 lighter by day's endExactly. SRAMs had it for about 10 years. (Maybe they had a patent that ran out?)
Makes changing the rear on my commuter bike a bit easier. Not necessary, but it is convenient.
A whole new XT lever/master is cheaper than that blade replacement.Not technically new but replacement levers for Shimano appeared in my You Tube feed today, advertised as unbreakable @frenchman might need to put that to the test.
https://flomotorsports.com/products/copy-of-beta-brake-lever-1
Should had gooGle before posting. Maybe it’s aimed at dentists.A whole new XT lever/master is cheaper than that blade replacement.
Surprisingly I’ve never bent a lever.Not technically new but replacement levers for Shimano appeared in my You Tube feed today, advertised as unbreakable @frenchman might need to put that to the test.
Pauline has chosen to ride her Duke Lucky Jack SLS2 6Ters wheels with Vittoria Mezcal XCR 2.25" tires in Tokyo.
My old landlord was a dentist and he was a tight ass. It rocked my world when I saw him riding a K -mart bike too.Should had gooGle before posting. Maybe it’s aimed at dentists.
Pretty sure that's @frenchman's new wheel company.First I've heard of these wheels!
They look the business:
They seem pretty popular in Europe. I've been looking at building a set of wheels through r2 with their 28mm rim, pretty impressive at 310g with a weight limit of 110kg.First I've heard of these wheels!
Custom made Vittoria Terreno?First I've heard of these wheels!
DUKE Lucky Jack SLS3 6TERS
The Lucky Jack SLS3 6Ters is the new flagship rim in our carbon XC range. MTB rims profiles are differentiated as we do not ask the rims the same qualities while riding : A front wheel must give gr…www.duke-racingwheels.com
