Thanks good advice just have to find a length of metal tube/pipe from somewhereClamp the crank arm a in vice, pedal spanner, inox spray.
Use a length of metal tube to increase the leverage on the pedal spanner if needed.
Use softjaws to protect the crank if you don't want the arm cut up.
Thanks This is the plan of last resort!Take it to a bike shop and ask them to remove it if you can't yourself!
Yes am aware thanks!Just making sure you are aware the left crank/pedal have a reverse thread... I've seen many a spirit crushed by this bit of knowledge.
Knock some scaffold tube offThanks good advice just have to find a length of metal tube/pipe from somewhere
The linked thread was great up until about post #63 where it becomes a soap opera which was entertaining!Oh dear God. Not this again...
Some advice - Vinegar is useless, sharkbearoctopus might be able to help... If you can track him down, Horatio will get the shits with you and don't even consider an oxy torch, WD40 or a dousing with freshly boiled water from the kettle.
http://www.rotorburn.com/forums/sho...d-pedals-are-stuck&highlight=god+pedals+stuck
Hmm seat post as a length of tube.... genius! I wonder if it will fit over the pedal spanner have to go try later!Get sharkbearoctopus to help you. . . . . If you can't find sharkbearoctopus (he often skives off to the pub when there's work to be done) then do the following.
Give it a good soak soak in inox or WD40. Pour boiling water over crank and pedal. Use seatpost on pedal wrench to give you extra leverage. Celebrate getting pedal off by watching 14 hours of German midget porn.
have also tried using harsh language!Shout at it.
I've never had that work for me, however I did once quietly tell a pedal that if it didn't come off I would send it to live with John Saffran and it removed itself of it's own accord. True story.Shout at it.
