AM She’s Crafty, she gets around…
Cyclomaniac
Glad you are liking it moorey, I am still loving mine. I converted my Cane Creek air to coil with a progressive spring. Lost a bit of pop and pedaling efficiency but didn't gain much of the coil feel as I would have liked. I now need to use the climb switch.
Watch that idler when wearing long pants, I got a baggy pair of work pants caught up in it the other day, ended badly for my pants, could have ended badly for me in the wrong situation.
lightbrain about 4pm
He is still in short pants. They are long but you know what I mean.
Long….pants? I’m a Ballarat lad.
Cheers. Just for giggles, I’ll try a monarch debonair, CCDBA and an older coil shock. Compression lever isn’t doing much, I’ll check it’s reservoir air pressure tomorrow in case it’s lost a bit. I know the T3 are fickle like that. It’s feeling fine to ride though.
More of a red hot crack on the Crafty today.
36km with 1200 climbing.
378866
378867
DVO reservoir was a bit low (130psi. I’ll need to keep an eye on that). Pumped to about 185, and it’s feeling a lot better all round.
One small hurdle, and one I was aware of when buying, the water bottle fouls under compression. Had hoped the Fidlock wouldn’t, but alas.
Do I?:
-Try swapping out shocks to check how other go? Really liking the Topaz TBH.
- Hit the bottle gently with the heat gun, and push the offending corner in 5mm?
378868
shiny
Go-go-gadget-wrist-thingy
Can you tweak the Fidlock mount so it slides up a few mm or will the top of the bottle not fit in the triangle?
It all the way forward unfortunately. Tons of room up front. Crafty ran it way lower than necessary. COG, I guess.
Jpez
Down on the left!
I think you can get adapters designed to move the bottle further up. Problem solvers maybe??
damn good effort on that ride too.
Tons of room running the smaller bottle with different profile…but 400ml not enough for a decent ride.
378872
Bit of 25x3 aluminium flat, drill two holes where it needs to bolt to the frame and tap two further along to move the cage. Paint it black.
Or buy this ^
Does that frame say TRUMP?
