If someone has just welded over the crack there's a good chance it will eventuality come through again. Depending on how the bike is ridden it might take 6 weeks or it might take 6 years. The best way is to v the crack out and test it for cracks coming through as you're filling the metal back up. By looking at where it's cracked, it looks like a stress point to me.Yep.
Except this isn't an alloy head and isn't subjected to the heat, stress or even movement of one.
Would I weld a head and trust it? No.
Would I weld a chainstay and ride as hard as possible? You betcha.
With regular inspection there's more chance of an axle failing under load than the weld suddenly letting go.
As much as I enjoy a Moorey fail post, we ain't gonna see one as a result of this.
Sent from my SM-G975F using Tapatalk
Just ride your bike Moorey, you will not come to grief doing 2 foot hucks.Fortunately, I am impervious to your skepticism
*You’re.Just ride your bike Moorey, you will not come to grief doing 2 foot hucks.
*Yore*You’re.
*yaw*Yore
*Yawn*yaw
I thought it was a "this looks like a tradie, will it kill me?" threadis this going to turn into one of Haakon's "this looks bad, will it kill me?" threads.
Just drill holes at the end of the crack. Worked for my grandfather maintaining spitfires in the war.If someone has just welded over the crack there's a good chance it will eventuality come through again. Depending on how the bike is ridden it might take 6 weeks or it might take 6 years. The best way is to v the crack out and test it for cracks coming through as you're filling the metal back up. By looking at where it's cracked, it looks like a stress point to me.
Somehow I doubt this is a simple weld over.If someone has just welded over the crack there's a good chance it will eventuality come through again. Depending on how the bike is ridden it might take 6 weeks or it might take 6 years. The best way is to v the crack out and test it for cracks coming through as you're filling the metal back up. By looking at where it's cracked, it looks like a stress point to me.
2 foot now?Just ride your bike Moorey, you will not come to grief doing 2 foot hucks.
Committed to memory, hadn't thought of that one.*Yawn
I’ll forget what now?
- No.
- Yes. Still 6” higher than you.
- Yule forget.
Too mainstream.If only there was a frame repair expert operating...
@Grip was the only person I would have trusted with it, but he doesn’t do repairs any more.
