fjohn860
Alice in diaperland
Depends what are supplied/specified by the rims. If washers aren't specified, it's a heap easier to build without them.
Yep, buying one rim which comes with the proprietary nipples and washers.
Might be getting another rim without the proprietary nipples and washers.
Just wondering if anyone has built up dt swiss rims (xm481 specifically) using different brand washers and nipples with success.
The Duckmeister
Has a juicy midrange
If the supplied nipples are aluminium, turf 'em & use brass, but still use the supplied washers, they're shaped to match the rim. Washer thickness is also factored into the ERD measurement.
fjohn860
Alice in diaperland
Yes, I believe the supplied ones are alloy. Have heard the dt swiss alloy ones are alright.
But have always thought brass was a better option.
Litenbror
But totally worth it (3C) on the front?
3c is softer so more grip but wears faster. More grip on the front and longevity on the back. Saying that I think I have dual compound on the front of the hardtail and that thing grips like hell in corners (DHR2).
TLDR - don't put soft compound on the rear unless your racing as they wear out super fast in my experience.
HamboCairns
Thanks for all the bananas
Good to know! Looks like I'll be cheaping out on rear end rubber from now on. Cue all the weirdos with their gay jokes..
Knuckles
Lives under a bridge
2C side knobs are super soft, and can squirm around under heavy cornering on hard surfaces, 3C have soft caps on hard bases for the side knobs, which hold their shape better when cornering, but they used to shear off at the interface. Not sure if they still do....it's been a long time.
#freebritney
HamboCairns
#freebritney
I sheared off a side knob from a 3C DHR II (on the back). Although that was a freak vertical load incident rather than any kind of cornering event.
Knuckles
Just get 70a and save a ton of money and increase your speed.
Disclaimer: any and all monies saved will be required towards near future medical invoices.
#freebritney
rextheute
Give Trek in Hoppers a call - or the Port Melb store .
Both carry a lot of spares stock ( as in if i have borked something they usually have it )
