Years and years and years.How long do people headsets last for? I seem to be going through a headset phase. Done 4 of my 5 bikes in the past month. If i had known I should have bought the actual tool.
What are they failing from ? I usually get a few years out of them.How long do people headsets last for? I seem to be going through a headset phase. Done 4 of my 5 bikes in the past month. If i had known I should have bought the actual tool.
I've got CKs that are probably a decade old with no sign of wear.How long do people headsets last for? I seem to be going through a headset phase. Done 4 of my 5 bikes in the past month. If i had known I should have bought the actual tool.
Very subjective but in my experience:How long do people headsets last for? I seem to be going through a headset phase. Done 4 of my 5 bikes in the past month. If i had known I should have bought the actual tool.
CK, forever.
Cane Creek cheaper ones, 1 to 24 months. Probably goes for FSA also.
Cane Creek 110 seem better, 1 to 3 years maybe. They do have that new hellbender bearing now that they offer with lifetime warranty.
#doyouevenrideFar out man, are you rampaging dh courses with roadie headsets? They all last forever! Even cheap and shitty ones last...I've tossed a few over the years, but not many. Keep them clean lubed and tight for a happy life of fat ploughman riding and jump casing.
Same here, I've had one cheap set fail from water damage and most likely from washing the bike with high pressure water.Far out man, are you rampaging dh courses with roadie headsets? They all last forever! Even cheap and shitty ones last...I've tossed a few over the years, but not many. Keep them clean lubed and tight for a happy life of fat ploughman riding and jump casing.
Not sure. I run the fork mud guard and don't even wash the bike (I think my 2013 bike has been washed 5 times in total). The symptoms are a bit of play under brakes. Rotation wise, they are fine and not gritty at all.What are they failing from ?
You can usually adjust the play out of them if they haven't been left too long. Some headsets need shimming washers or they bottom out when you re-tighten them. It's not impossible to have headset bearings wear out but to have so many at once is a bit out of the ordinary.Not sure. I run the fork mud guard and don't even wash the bike (I think my 2013 bike has been washed 5 times in total). The symptoms are a bit of play under brakes. Rotation wise, they are fine and not gritty at all.
You should see my brake pad life too!#doyouevenride
Isn't your motto "Ride for life" you don't even own a car ?You should see my brake pad life too!
Cotic Solaris (2013) | Transition Smuggler (2016) | |
M | M | |
ETT | 604.5 | 590 |
HA | 70 | 67.5 |
Chainstay | 440 | 436 |
Reach | 429.3 | 432 |
ST angle | 72.5 | 75.4 |
loosen stem bolts... tighten centre cap bolt into star nut, symptom resolved.Not sure. I run the fork mud guard and don't even wash the bike (I think my 2013 bike has been washed 5 times in total). The symptoms are a bit of play under brakes. Rotation wise, they are fine and not gritty at all.
~15mm is a lot of ett. But you'd have more reach. Smuggler was probably designed to run a stem shorter than 60mm as well, so maybe it's going to balance out.Ok - rider fit question - ETT vs Reach & seat tube angle: if the first bike (Cotic) here fits me well, should the second (Smuggler) fit well too? even with a shorter ETT (due to steeper seat tube?) These are only geo numbers I can quickly scrounge for both...
Cotic Solaris (2013) Transition Smuggler (2016) M M ETT 604.5 590 HA 70 67.5 Chainstay 440 436 Reach 429.3 432 ST angle 72.5 75.4
Additional info: I run the Cotic with a 60mm stem (shortest recommended for that version, tried 45 and it gets me too cramped). Also ride a L Process with an ETT of 629 and reach of 460, but that bike is more for plowing over everything (and is probably too big for trail riding - which is 95% of what I do now)
I ride fairly often. Not a lot of braking around the city though. On trail I'm a cross between plough and nervous nanna. Way too much braking straight into trouble.Isn't your motto "Ride for life" you don't even own a car ?
Nah sounds like he needs to throw it in the bin. Should probably bin the whole bike actually. Just to be safe.loosen stem bolts... tighten centre cap bolt into star nut, symptom resolved.
Check the stack too as that effects reach a bit.Ok - rider fit question - ETT vs Reach & seat tube angle: if the first bike (Cotic) here fits me well, should the second (Smuggler) fit well too? even with a shorter ETT (due to steeper seat tube?) These are only geo numbers I can quickly scrounge for both...
Yeah I tried that already. The added problem is on one of the bikes the fork is actually stuck on so I rekon something is wedged in real good.loosen stem bolts... tighten centre cap bolt into star nut, symptom resolved.
