dirtdad
Grip tape? Silicone lever condoms? Your fingers?what's that grippy stuff you can apply to brake levers?
Grip tape - is that the same stuff you put on the steps or ladders etc? Don't want to buy something that's mega stiff and won't wrap around levers etc.Grip tape? Silicone lever condoms? Your fingers?
Do you need it to wrap? Will a straight strip where your fingers touch do the job?Grip tape - is that the same stuff you put on the steps or ladders etc? Don't want to buy something that's mega stiff and won't wrap around levers etc.
Yeah just the front of the levers. Is it good for the inside arms of sunnies too?Do you need it to wrap? Will a straight strip where your fingers touch do the job?
Then go next door to the LBS and set up a direct debit on a pre-paid purchase agreement for a new pair of gloves to be sent out every 3 monthsI think you need to hit up your local skate shop.
Tek screws. If you arent taking the piss...Yeah just the front of the levers. Is it good for the inside arms of sunnies too?
If your sunnies are slipping you're better off shaping the arms... Fuck griptape behind the earsYeah just the front of the levers. Is it good for the inside arms of sunnies too?
I don't understand?Tek screws. If you aren't taking the piss...
Might be the wrong thread for that sort of question.I don't understand?
All the rubber has perished (Cairns!) on the inside of the arms so I wondered if the lever grip tape was suitable. Doesn't sound like it is!
Yeah I'll keep GooGlingMight be the wrong thread for that sort of question.
Google "Oakley sock kit"Yeah I'll keep GooGling
Grip tape is basically self-adhesive sandpaper, don't think it's going to do your ears/head any favours.I don't understand?
Is this the same one to fix up tyre punctures?For levers, a couple of stealthy blobs of Sikoflex (the shoe repair one) might be a good option. I’ve been considering trying it, as the thumb/finger pads on my current gloves are really slippery on my levers when I get really sweaty.
Do you even tight arse?orSticky Fingers - Brake Grips -Miles Wide Industries
Simple, rubber slip resistant brake grips.miles-wide.com
Pushys sells both
No cause it generally costs me more in the long termDo you even tight arse?
