I need some decent trail tyres. How are those lovely chunky Michelins going? And I need to replace my rear shock and ask Santa for bigger balls.
well if anyone is the right person to ask for bigger balls its gotta be the man with the big sackand ask Santa for bigger balls.
But he empties his sack only once a year and the contents are mostly for kids!!well if anyone is the right person to ask for bigger balls its gotta be the man with the big sack
Im rating my Michelin wild grip r replaced a maxxis aggresor on the front and Im really happyI need some decent trail tyres. How are those lovely chunky Michelins going? And I need to replace my rear shock and ask Santa for bigger balls.
The issue and potential for problems with jacking up the front end isn't so much the BB height, it's the slackening of the head angle beyond its designed parameter. As the head angle is slackened, the stress path becomes more across the head tube and - crucially - the welds rather than along the tube axis, so the head tube area needs to be beefed up. If you slacken the front too far beyond its intended angle, you increase the risk of breaking the front end off your frame.So I am currently riding a Nomad Mk2 (26") and after picking up a set of 160mm Lyrik RC's from MTBD and needing a new front wheel, decided to get a 27.5 front so now running a 27.5 front 26 rear. I am going to do the debonair upgrade and need some advice from the brains trust (use that phrase very loosely);
Is increasing the front end to 170mm going to raise my BB too much? I know just going to 27.5 will make an impact to head angle and BB height but will raising the travel push me that bit too far?
Also oil for lowers is supposed to be 0w30 but I have a bottle of Rock Oil SVI suspension fluid in 15w unopened is this useable?
https://www.chainreactioncycles.com/au/en/rock-oil-svi-suspension-fluid/rp-prod8399
I’m running 15w in a Pike, Lyrik and a mates Pike and it seems to do the right thing.So I am currently riding a Nomad Mk2 (26") and after picking up a set of 160mm Lyrik RC's from MTBD and needing a new front wheel, decided to get a 27.5 front so now running a 27.5 front 26 rear. I am going to do the debonair upgrade and need some advice from the brains trust (use that phrase very loosely);
I'd say DIYMTB for the win.Where do you find aftermarket low friction fork seals for 2018 SIDs
They weren't in my Santa Sack
200mm rotors...the black "Web" part was fouling against the calliper.I have XT Ice Tech rotors working nicely with Hopes. What was the issue?
Which means that you had 203mm rotors and needed some shims or a 203mm adapter.200mm rotors...the black "Web" part was fouling against the calliper.
Probably. Says 203mm (edit here - just checked rotor because i got curious) on the rotor and the forks are Marzocchi 66, so 200 is their default rotor size. I probably could've messed around with some shims looking for the sweet spot (I've got more than enough of them in the small parts organiser), but I had some conventional rotors in the collection that have worked out just fine.Which means that you had 203mm rotors and needed some shims or a 203mm adapter.
Just been dealing with this. Used a combination of different centerlock adapters but it's working.I had to move to the Shimanos to get centre lock to stop the Hope’s fouling the caliper mounts because the 6-bolt adaptors pushed the rotors out too far...ah standards...
