The stupid questions thread.
Easy tiger! You'll be wanting 8 big ones front and rear for that.
With all the standards for bikes being changed back and forward up and down, when will ~8 inches no longer be the standard for dh travel? What will be next?
And when is 20mm making a come back???
Don't egg them bike engineers on, they'll go to 30mm and fuck us all. :D
Didn’t Maverick do a 24mm axle on their DUC fork? So the engineers can’t go too big too soon and will need to go in between, so would be 22.89 and it’s not a new sramnard just a new axle....
359763
Yes they did. Pretty sure that wold be one significant reason their forks didn't sell so good
WTF is being made at the north entrance/exit of the Prospect Water Filtration Plant.... willing to supply chilli sauce to the correct answer..
Yes, the meat sock has lots and lots of chilli
S
S
Zombie apocalypse protection barrier to secure the water supply so you can make MOAR chilli sauce whilst under zombie attack.
S
Anti ISIS screens. The 20mm autocannon is tucked around the corner and camouflaged to look like a boom gate.
They are still building warehouses on Reconciliation Drive too.
A new drive-in? Another water park that costs $100 to get into? A pump track?
I'll be around that area about dawn, I'll try to remember to go have a look.
S
My best guess is 'a working model of Manus Island.
I found this a few hundred metres up the road,
360192
.... which leads me to believe there's a world class gravity enduro MTB park being built nearby.
OK say a Red Belly bites another Red Belly will it die?
No. most snakes are evolved from fighting each other so they are used to it.
Stupid question from my end:
Anyone DIYed a spank vibrocore? Specifically I'm thinking of doing this for a gravel bike drop bar configuration.
You thinking expanding foam?
You got it!
You'll be wanting PU foam then and not the two pack stuff. And you'll be wanting a longer hose than what is typically supplied with those tins. I've been using Wurth Prologic Top as a sealant adhesive and it's great but it only works with their gun...another $25. Other option is Soudal but they use a floppy dick hose...
