Did the whole cut/paste, whole reformat... checked for bookmarks and indexing as well- nothing. I show formats whenever I pick up someone else's docs for that reason haha it's usually fucked from some line/page break issue. Ended up deleting the problem area, saving a couple revisions and printing on those pages... managed to somehow get it right. Plain format paste helped but I wasn't doing the whole document again!
Got lucky, thanks guys!
At $500 what specs should I be looking at to get the best value laptop? Or are they all pretty basic and similar at this price? Only used for interweb, assignments and such. However at this price I wasn't sure if cores, processors and all that really came into play.
http://www.rotorburn.com/forums/showthread.php?t=283821At $500 what specs should I be looking at to get the best value laptop? Or are they all pretty basic and similar at this price? Only used for interweb, assignments and such. However at this price I wasn't sure if cores, processors and all that really came into play.
That's fine, although you probably wouldn't want any more than that. You need the steerer top to be some way below the top of the stem to ensure you can tighten the headset. If there's not enough gap the underside of the cap bottoms out on the steerer & you can't pull proper bearing tension.
Thanks,
I researched how to tighten up the headset but most other pics online seemed to have a smaller gap.
I guess I'll just check it after a few rides.
I installed a Easton stem the other day and read the instructions out of boredom.
From memory they said 2-3mm MAX, as long as it's about the top bolt by a little more than halfway good enough for me. You got some stem spacers you can play with, could always move on to the top if your concerned.
not sure if this is 'showing the formatting' that you are referring to - but the shortcut [ctl-shift-8] shows up some pretty funky formatting (that's the number 8 not F8)
yeah it's got a 2mm spacer I could use but with the 2mm the head cap enters the stem it get's close to hitting the steerer tube.
I'll go for a few rides and see how it beds in, if it does at all.
thanks mate
Is it hypocritical for my hippy mate to fly to New York to attend the international day of climate action?
