Sorry if I sound like a numpty, but it's hard to get my head around leverage ratio graphs and apply them to my bike. Would you expect the corset to work well with a VVP style leverage ratio?
I only ask as I have a 2011 575 (essentially the same a 2013) which apparently has a very simillar leverage curve (found on
http://linkagedesign.blogspot.com.au) to the VVP curve listed earlier. I am a little hesitant to give one a go as I'm unsure if it will work well with the 575 design but also my weight (120kg) requires 250psi in the shock already and I've been told I might have to increase that to 300psi or more if I fit a corset. Steve at Vorsprung didn't comment on my frame design and if it would work well or not with it.
Would the corset's increased spring rate in the midstroke help with the higher leverage ratio of the 575 to remove the blow through?
