I haven't run metrics but I'd be glad to hear your thoughts on the Slants.
Light, stiff, adjustable (air plus rebound), cheap. Not as plushy as my previous Fox 36 Van (coils) but definitely not sticky like you'd assume when comparing air to coil. It only takes some hand force to get them started through their travel especially if running lower PSI. Not like my girlfriend's cheap arse RST air forks. HEAVY, STICKY, would almost be better to run a rigid fork with flat tyres.
Lockout handy for up hills, rebound has around 30 clicks of adjustability (and works more precise than the 36's). When in lockout you can feel them flex under load (I've forgotten to take it out of lockout a few times and bombed the start of a run). Takes 203mm discs with no adapter (might be an issue if you want smaller discs)?
15mm Axle end is annoying but you can unscrew the lever end cap off so it doesn't look like a bat-wing when you're riding.
34mm stanchions, 160mm travel, easy to service, videos online, diymtb are a good supplier (when they answer their emails). Did I say they're cheap?
Only reason I want to go with Metric's is more travel. Basically I'm hoping for the exact same thing + 20mm more travel (and a refreshed front end look, going from white forks to gun metal or black). I'll most likely miss the weight saving and lockout though.
:bananalama:
