I set limit and b screw with chain on with the derailleur I just fitted. This is a second hand 8100 I picked up so this was first time fitting. I always set b with chain on as I see it as this is were the derailleur will definitely sit while riding (under tension). Limit screws I normally set without chain or cable first then do a final check once everything is fitted up.
