@DMan doesn't have the tool?Anyone know if the lock ring removal tool is just a BB tool of something proprietary?
Looks for all money like Shimano BB tool.
The measurements I just found correlate to that standard BB tool (16 notch, 44mm OD). Will work it out when it comes. Cheers Duck.Same size as the new smaller OD bottom brackets. Not sure if the plastic adaptor would be hard enough for the smaller contact area of the chainring nut.
Nope. New set might have tool. He''ll need it I imagine.@DMan doesn't have the tool?
Sent from my SM-G960N using Tapatalk
So it isn't the same tool that you can use for centrelock lockrings/ BBs @The Duckmeister ??Same size as the new smaller OD bottom brackets. Not sure if the plastic adaptor would be hard enough for the smaller contact area of the chainring nut.
The internet lied to youSo it isn't the same tool that you can use for centrelock lockrings/ BBs @The Duckmeister ??
If your new cranks come with a tool, can you post with my cranks after fitting yours, and I’ll return.So it isn't the same tool that you can use for centrelock lockrings/ BBs @The Duckmeister ??
YepI've got one of the new bottom bracket tools free if anyone needs one.
I'be only got a plastic adaptor. Cheers for yours.That's the one. Fits snug in the original tool.
Yeah, internal one too. For an external lockring....Thanks Duck. The intenet makes it harder to find correct info, not easier. DMan contacted Pushys, they insisted it was a cassette lockring/CL tool.
