G
Nice would be great to go there
So i have worked out that i don't know what my rebound, high, low speed adjustment really do or in what sequence to setup.
After lots of you tube clips i worked it out.
this is what i concluded, and am working on front and rear
Set sag .
then adjust so you get full travel ( on a bit of trail )
45 psi forks
210 psi rear shock
Set rebound
using the push down on the bars method
3 clicks from fast - forks
4 clicks from fast - rear
Set high speed ( sharp square edges, bumps )
will be doing this weekend
Set slow speed ( pedal bob brake dive )
Also read start with min full anti clockwise, then ride and increase to happy.
So never new enough and usually just guessed consequently made it all feel worse.
