And chains.Yeah, cranks, stems and bars from reputable sources for me...
Is @pink poodle a reputable source for pedals? Asking for a mate.Yeah, cranks, stems and bars from reputable sources for me...
Has anyone tried something like this?
Winow updated 29ER MTB Carbon Fork 110*15MM Boost Cross Country Mountain Bike Carbon Rigid Fork With Water Cage Eyelets - AliExpress 18
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Death trap?
So, a couple of month since these posts. I found the listing on a few sellers, all turning out to be the same seller under different names. Each time I asked, I was told initially "back in stock soon", then to "not being produced, buy this one at twice the price", to which I quite happily said no and bided my time. It wasn't a required purchase by any means, and was still waiting on word of the new Seido Taza fork.So, I reached out to one of the sellers for some more info, as the Eyelet version is out of stock. Apparently back in stock in about a month or so.
I also asked about the eyelet limit, it's 3.5kg per side, which is pretty good. Not class leading by any stretch, but enough for some Any Cage brackets and to load with some light stuff.
Definitely on my hit list now!
Update!! Did a few rides and it survived black/ double black runs. Tried to take off cranks to access chain guide and rounded off both crank arm bolts(made of cheese). Not sure if I hand tight it too hard but now gotta hacksaw/grind off the axles. Will be returning back to shimano cranks.View attachment 411756View attachment 411755
Been going a little crazy with the AliExpress purchases. There is another version called Bucklos that only comes in 170/175mm and these Evosid had 165mm so went with them. Installed the crank with a new Sram bb and Garbaruk chainring. 0 instructions or torque specs included.
This replaced a gx crank, there was a lot of preload to be added on this crank where i felt there wasn’t threads left so i added a 3mm spacer to reduce it. Will update if the crank is still in one piece.
So far the other AliExpress purchases are holding up, the One-up chain guide, Dagga pedals and Title stem.
The Ali SRAM chainrings are cheap too.Yeah, the bolts are where I've realy noticed the difference on the Senicx FM3 (Hollowtech Clone) cranks. As long as the tool is properly seated, it's all good, but on the first install I didn't pay close attention. Thankfully I felt the deforming before it got serious, but when I check the cranks at 1000km, I'll probably pull a set of bolts from one of the retired Shimano cranks in the shed.
If Shimano bloody well made an SLX Crank in 165mm, I probably wouldn't have bought Ali, but I really do like the Sram-style chainring mounting on the Ali cranks. I'm now down to only 1 bike out of 7 in the shed that doesn't use the 3-bolt pattern.
Yup, I wish I'd come across them sooner than the Monster-Gravel build, as last year I forked out a LOT on Absolute Black Ovals, only to find a really good Ali clone when building the aforementioned bike. Ah well, a good test to see how long the Ali vs AB rings last.The Ali SRAM chainrings are cheap too.
I've just replaced some blown up DT240 freehub bearings with Fushi 6802RS... seem smooth/tight enough. Also bought one of these https://www.aliexpress.com/item/1005007317164178.html - pretty nice bit of kit, could recommend.Suspension bearings on the cheap. Needed a set of 10 (!!) bearings for the Trance, spread over 4 sizes... This mob sell them in packs of 4 so ive ended up with a few spare ones, but was still about $50 for the whole rebuild set. Half the price of the usual sources.
Bearing seemed to be good - full complement as you expect and reasonably well greased, although i popped the seal on them anyway and packed in more. They ride well
FUSHI Official Store - Amazing products with exclusive discounts on AliExpress
Discover the wide range of from AliExpress Top Seller FUSHI Official Store.Enjoy ✓Free Shipping Worldwide! ✓Limited Time Sale ✓Easy Return.fushi.aliexpress.com
I don't, but given the Optislick cables are relatively cheap, I'd wonder if the Ali ones would corrode pretty quickly. From what I've seen of most of the steel off-brand components, it may end up a quickly changed cable!Does anyone have experience with the generic shift cable housing from Ali? Wondering about longevity compared to Shimano.
Curve Seek 500
Edit [Whoops, you need outer, I use the jagwire when I want cheap outer.]Does anyone have experience with the generic shift cable housing from Ali? Wondering about longevity compared to Shimano.
I've bought a few metres of gear and brake cable housing. I use them on kids bikes, and on cheap repairs. There is no discernible difference to the more expensive name brands to my eye. I'm happy using them.Does anyone have experience with the generic shift cable housing from Ali? Wondering about longevity compared to Shimano.
