I've just bought a $20 saddle and enough bearings to do 2 bikes for $58
I've been running these chainrings for the last few years, they work well however I do seem to loose teeth off them but that is probably from bashing them on things.
I've had a couple of pairs of these shorts. They do the job but they do have issues, mainly stitching in the pockets.
Love this tape, beats the shit out of the whatever random cloth tape I had on the shelf Id normally use.
Been using these pads for years, no real issues to speak of.
Upgraded to 203mm rotors on centrelock hubs using the below. Maybe these discs are a bit thinner than shimano but I have had trouble adjusting the levers far enough out from the bars after swapping (I like the levers engaging a long way from the bars).
These hubs aren't on my main bike but I think I've done about 500km on them, not a particularly easy 500km either. Planning on building another set of wheels with these at some stage. Cant fault them yet.
Using these shims on both my bikes, seem to do the job.
These were fine, still in my forks
I've broken a couple of these axles, not sure if its my fault from over tightening or if they are a bit weak.
Why the fark is the cable on these joined with a magnet? I just wanted a wire with a fitting on the end to drag cables through.
Fixed it by cutting off the magnet and soldering the cable directly to the fitting.
Buy these grips in bulk. Leave them out in the sun for a month so they go sticky and soft and they are sweet.
Chain kept getting stuck between cage and jockey wheel with these. no good.
Awesome
Awesome
Great place to get genuine shimano bits
Some of the cogs bent just from normal riding - id hope they have fixed the issue by now.
Good pump, fitting works on my rockshox shox I have to file the shrader fitting down on to fit in the scott genius.
Good shock bolt, still going strong
Does the job, no idea how accurate it is calibrated but at least I can get the spoke tensions even (pretty sure its accurate anyway).
