steve jobs' pancreas
Both
Bluetooth for trainer
ant for cadence sensor
Bluetooth for Power Source, Cadence and Controllable.Are those on PC running Bluetooth 5 or ant
My cadence on ANT+ is not as responsive during ERG than it is on BT.Both
I have a trek with duotrap cadence sensor, only runs on antMy cadence on ANT+ is not as responsive during ERG than it is on BT.
Every computer/trainer is different though.
Did he combine shipping?Ended up scoring a GPU on eBay from a bloke who sells PC parts, ball gags and leather underwear
I didn’t realise @Minlak sold computer parts.Ended up scoring a GPU on eBay from a bloke who sells PC parts, ball gags and leather underwear
Yeah I overpaid for the GPU for the discounts on the other itemsDid he combine shipping?
Shouldn't your trainer do control, Power and cadence all in one stream?Bluetooth for Power Source, Cadence and Controllable.
ANT+ for HR.
I bought a Wahoo dual HRM and was running it on Bluetooth but the Zwiftalizer program showed the 4 x BT connections were not as stable as the trainer connection only on BT and the HRM on ANT+.
Make sure and check on your connection screen before starting that they are on the right setting.
I believe (been a while) its my cadence that tries to start on ANT+ automatically every time I start it. I then manually select it to BT.
Makes sense. I make sure it is doing all in one connection.Shouldn't your trainer do control, Power and cadence all in one stream?
Have you tried using your phone companion app as the bridge? I loosely assume this wouldn't require your PC to have bt or ant, just be on the same network...Makes sense. I make sure it is doing all in one connection.
If I didn't have 2 connections it might just pick BT. Each of the 4 items can be selected to run on whatever sensor you want. Just hit unpair and you can select the connection.
I use the companion app while riding to give ride-ons and track gaps/riders.Have you tried using your phone companion app as the bridge? I loosely assume this wouldn't require your PC to have bt or ant, just be on the same network...
But I also assume this would lag
Unless you use an Apple TV.This stuff just doesn't work 100% from go... I reckon we all have had a bit of a trial and error battle.
True, but why settle for Apple TV graphics when 4k is available, the crisp shadows, the butterflies, the snow flurries, the muscle definition on my virtual shaven legs...Unless you use an Apple TV.
Yeah but then you have to have an apple device in your homeUnless you use an Apple TV.
Yeah, but it fake, faker and fakest. Computers can be annoying. But, yes generally higher performing / higher maintenance.Its a big difference... still just an animation but it makes a big difference.
I purposely built a computer to run Zwift, well it was an old one that I upgraded. New graphics card, new SSD, new BT and wifi card and then Zwift didnt get along with it.Yeah, but it fake, faker and fakest. Computers can be annoying. But, yes generally higher performing / higher maintenance.
A while ago you were preaching apple TV was the only way to go?True, but why settle for Apple TV graphics when 4k is available, the crisp shadows, the butterflies, the snow flurries, the muscle definition on my virtual shaven legs...
A few have only went Apple after the headache and to be honest, I was nearly there too.
I think that is the zwift club overlord, aka @rockmooseA while ago you were preaching apple TV was the only way to go?
