Nsd can change the shim stack when you get the damper installed. The debonair spring is a seperate part that is surprisingly cheap. You might as well get it all done at the same time.
Oh, so the shim stack tuneis a seperate thing? Which I assume incurs an additional fee.
Here's what I pulled off the nsd website.
"The ‘Super Lyrik’ includes all of the following upgrades
FAST Suspension Hi / Lo compression top cap
FAST Suspension compression circuit
FAST Suspension rebound circuit
NSD ‘Soft Touch’ air spring upgrade
NSD ‘Hyperformance’ service upgrade
Total Cost: $600"
What I was trying to say is I'd only want the fast upgrades not the other stuff. So was hoping you had found it offered elsewhere as a standalone thing.
The debonair spring looks super easy to install.
It is a shame that the fast cart requires existing parts from the charger damper as it would be perfect if you could just drop the whole new assembly in.
