Gripsport finally have a vertical rack:
Scoobs looks to be struggling with the weight.
Angle of the dangle. Interesting. AMB have a review out soon.
Looks like a good rack. The sidecar hoops are a good idea for kids bikes and the light bar is great but still not technically legal, as you need to see all lights at a 45-degree angle. Kind of make all racks illegal really if you go down the full letter of the law.Gripsport finally have a vertical rack:
Gripsport Versa 1.4 Vertical Bike Rack | GripSport
The Versa vertical bike rack designed for vehicle's to transport your bikes. This rack holds up to four bikes and has a tilt function to access your boot.www.gripsport.com.au
4x2 Hilux - any good carrying options for two bikes or just lie them flat and strap down?
MTB's do not fit on a current Hilux tub tray longways without the tailgate dropped.
sounds the gostrap them down MX style by putting straps over the grips and cinching down to tie down points
It's one of these and the tray is enormous
Go full moto. If its good for 100kg of moto, it's good for any bike.
That clearance spec is offGripsport finally have a vertical rack:
I had the same issue when Mrs @nzhumpy pulled the rack off with out unplugging it first, pulled some of the wires out from the round 7 pin to flat pin converter, was easy enough to relace.Question, which is bike rack adjacent (Potentially one for the quick question thread?)
I've got the older version of the below Thule bike rack.
Ever since I had it the lights have been a bit hit and miss - Think likely because the wiring gets pulled around a bit and maybe some euro conversion issues.
How difficult is it rewire it up myself?
I'm a real novice with electrical related stuff beyond connecting speaker wires
I’ve done plenty of fiddling with the wires inside the converter. Would have pulled it apart 10+ times. Getting the wiring colours and numbers from Thule was like pulling teeth, took weeks.I had the same issue when Mrs @nzhumpy pulled the rack off with out unplugging it first, pulled some of the wires out from the round 7 pin to flat pin converter, was easy enough to relace.
Yeah, just do that. Although if cables from existing components are good, I wouldn’t rewire those, just reroute to your new wiring and connect up.I was hoping to bypass it all and run fresh wires throughout
Hi folks, new car, new racks.
Got a Suzuki GV (on with the spare wheel on the back)
