I'll get around to it one day. Maybe trailside.Fuck, I'd to see the colour of the fluid when you do get around to it. I also shudder more than an Elixir brake to think how they'd perform on a big descent.
Yep, vac bleeding Guide RS or RSC , it makes a rear brake feel like a non vac bled front, eliminates a lot the sponginess. Makes a front lever feel rock hard and super responsive. The flip side to this, you're still left noticing the rear plastic lines swelling under pressure.@link1896 I've noticed that SRAM no longer even include the degassing step in their bleed procedures, do you notice much difference in the results when you vacuum bleed?
Uberbike sell a universal kit but they only have a very limited stock of line colours.Yes, I had to replace a rear brake line just this week and despite a token effort couldn't find anyone selling braided lines for Guides, specifically S4 caliper but I don't think that there is a difference in the banjo anyway.
Goodridge kits are here https://www.tweekscycles.com/compon...ngs/goodridge-avid-hydraulic-braided-hose-kit
Hmm. Maybe just google tweeks cycles goodridge.That link is no good..
Thanks, I did see those but as I'd had a nasty encounter with a stick and wanted to get the bike back up and running without delay I decided to stick with MTB direct, I'd just wrongly assumed that braided lines would be more commonly available.Uberbike sell a universal kit but they only have a very limited stock of line colours.
Let me know how the upgrade goes Link, I'd be interested in your thoughts.URL works fine for me.
Kit 111 is what you want for Guides I believe. I think I will be ordering some.
Looks like coffee! I'll be doing a pair that are 26 months old....... So will post a pickHere's someone that thought the 1 year mark was a good bleed interval...
My crappy phone camera can't do it justice.
I don't think avid run Dot 5, Dot 5 is silicone based. You can use Dot 4 and Dot 5.1, auto stuff is no different from the gen Avid stuff.This is a great thread folks. I'm contemplating a bit of brake maintenance finally.
Is there any magical special sauce added to the Avid Dot 5 fluid or any old Dot 5 from the local auto emporium will do fine?
Not so sure about SRAM's dot compatible grease, request a MSDS if you want to see what's it's ingredients are, but the Castrol Red Rubber grease, which is used for every brake rebuild in the world thats automotive, is not at all corrosive, it's highly refined mineral oil derived.So I realise that DOT fluid is the devil and will eat through paint like a rabid teenager with the munchies would through your pantry, but what about the Avid/SRAM DOT compatible grease... is it corrosive as well?
*(petroleum jelly) / vasolene, without the red dye.Not so sure about SRAM's dot compatible grease, request a MSDS if you want to see what's it's ingredients are, but the Castrol Red Rubber grease, which is used for every brake rebuild in the world thats automotive, is not at all corrosive, it's highly refined mineral oil derived.
