The plastic spacers are not securing the fork in the headset, this is allowing play(creaking noise) between the bearing inner race and steerer tube. As seen in the image below, this proves there is potential movement in the headset and can cause damage to other parts including the frame.
Wear on fork steerer tube
Correct torque was applied using my warren and brown 1-24 Nm deflector beam wrench, so I'm confident that it was done correctly. Also using loctite thread locker on the threads to make sure nothing came loose.
Edit*
I found a reddit post with the exact same issue on the steerer tube, same visible markings.
https://www.reddit.com/r/MTB/comments/nbytqh/_/gzuqve2
Edit*
