Don't have that problem! (...yet)Did you find your glasses whilst looking for your belt?
Top left piston in that photo looks like it's coming out on an angle. Or is that just a trick of the light?Father, it's been a while since my last confession.
On Friday, I went to install new brake pads in the Stumpy ready for the "Railton Express" XC race on Saturday.
Had a bit of trouble getting the pistons to stay fully retracted to fit the new pads, so I had them in and out a few times. Anyway, I got them in without any disk rubbing, bedded them in on the street out the front of my place and all was good for tomorrow's race.
Race day and I set off in a good position in C grade and settled in for the 40km loop. Halfway around on a loose descent I could hear a grinding noise coming from the rear of my bike. I pulled up at the bottom and found that one of my brake pads had started working its way down between the calliper and the disk, but the retention pin was still in place. I worked out, that somehow, I managed to install the pads too far down in the calliper and the retention pin was on top of the pads. No idea how they stayed in there so long, but I had to fix it trail side, and I then found out that the two multitools that I carry both don't have an Allen key small enough to fit the retention pin. I then realised that all I could do is remove the rear wheel, get the pads out and stick them in my pocket and continue the race with no rear brakes. So that's what I did.
Had a couple of sketchy moments trying to pull up on the front brakes alone but it wasn't too bad. The hardest thing was fighting the muscle memory to not pull the rear brakes on. Lost about 7min and one definite position and another one to two possible positions to the couple that I was riding with before the issue.
Lesson: Need my old man's glasses when working on the bike from now on.
View attachment 413492View attachment 413493
You also don't seem to have the small retainer clip that goes on the end of the pin to stop it falling out
luckily that wasn't a steep track or it would have been mega sketch with only a front brake. !Father, it's been a while since my last confession.
I haven't even looked at it yet. I just dumped the bike back in the shed in disgust and left it.Top left piston in that photo looks like it's coming out on an angle. Or is that just a trick of the light?
Multi-tool without a 2/2.5/3mm Allen key? Off to the Black Friday Sales you go...
Who needs them when you don't even put the pin through the pads.You also don't seem to have the small retainer clip that goes on the end of the pin to stop it falling out
Yeah, there were only three reasonable descents left to do, and the front brake was enough, not comfortably enough, but I didn't die. I lost a bit of time there too as I couldn't go as hard on the downs as I would have liked.luckily that wasn't a steep track or it would have been mega sketch with only a front brake. !
Not quite there myself - it’s the Allen keys that keep moving on me.Don't have that problem! (...yet)
I have done that looking for car keys that were in my shorts pocket.Non-bike related, but still... Just went searching around the bedroom, then rest of the house for the belt I had already put on.![]()
You're not alone.one of my brake pads had started working its way down between the calliper and the disk, but the retention pin was still in place. I worked out, that somehow, I managed to install the pads too far down in the calliper and the retention pin was on top of the pads.
I didn't think it was even possible, let along that someone else has done it.You're not alone.
That's like when your looking for the matches and the last dude that had the bong is still holding them in his hand and he's forgottenI have done that looking for car keys that were in my shorts pocket.![]()
I left the bolt that goes through the pads out once. Didn't notice till Junction Cabin when I stopped check the rattle. Very slow trip back down North South trackI didn't think it was even possible, let along that someone else has done it.
or so I've heard!
You need to hold the match until all the matchhead sulphur has dissipated before moving on to the next step.Matches give the bong smoke a wierd taste.
I have also heard that if you like weird tastes, you drink the bong water after a session. Is there nothing more putrid?Matches give the bong smoke a wierd taste.
