XC Ducky's Modern-Retro Carbolicious (or is it Carboniferous?) Anthem. Now with v2 Project
@The Duckmeister This just popped up on FB and thought it might of interest to you.
Although assembly hasn't progressed since the last update, bits have been coming together behind the scenes.
The Spec so far:
Frame: 2012 Giant Anthem X Advanced SL, 18.5" (M)
Fork: OEM Giant blue Fox 32 F120 RLC; rebound, adjustable force non-remote lockout, low-speed compression adjustment, 120mm travel; supplied but not fitted 20mm travel spacer so I can drop back to original-spec 100mm if desired.
Shock: Fox Float RP23
Crank: Shimano M980 XTR 3x (XT middle ring), with BB93 XTR threaded bottom bracket.
RD: M985 XTR clutchy long cage for 3x10.
FD: M980 XTR low-clamp 3x10.
Shifters (yes, both of them! :p ): M980 XTR 3x10 bar clamp.
Pedals: M990 XTR Race, SPD 25th anniversary special edition, in blue ano finish.
Wheels: M785 XT "Race" 559 x 21mm rim, 100x15mm hub Front, M788 XT "Trail" 559x24mm,135x10mm rear.
Chain & cassette: Shimano HG 95 XT chain and M771 XT 11-36 10-sp. cassette. Have a M980 XTR cassette, but that will wait in reserve until I get the ultimate wheels.
Other: OEM Giant blue ano derailleur hanger & stem top cap; Hope Tech blue ano seatpost clamp. M9110 XTR 15x100 front hub for future build into a carbon rim...
Sweet.
Tyres, headset, bb, stem and handlebars, grips, seat and seat post left?
BB sorted, will be current XTR- spec BB93 threaded. Headset is standard Giant/FSA OD1 tapered semi-integrated. Cockpit (bar, stem, post) to be sorted; will be carbon, whatever I can find a matching set of, based around the key consideration of a flat handlebar that is not a mile wide..... Grips will be blue to fit the colour trim theme, but beyond that dunno yet. For saddle I'll likely nick the Fizik Gobi off the #2 bike, then look for something to keep that ready for backup duty. Tyres most likely Maxxis Crossmark II, they work for how I ride. Major missing piece of the puzzle is M980-series (preferably 988 "Trail") brakes; proving very hard to find.
Hung the drivetrain bits on it, and swapped cassette, brake rotor & tyre over to the M788 XT rear wheel donated by @Plankosaurus and fitted that in place of the 775 I had, so graphically the wheels now match. Chucked a tyre & rotor on the front, only for display purpose as they're a bit NQR.... :p Progress pics will follow soon.
Found on Fleabay a M9000 Q/R rear hub, mechanically identical but cosmetically different to the M985, but fits the colour theme of the 980 series. Slightly unfortunately it has the silly auction process & no "buy now" option, but so far I'm the only bidder, with three days to run....
Cockpit (bar/stem/seatpost) are currently shaping up to be Ritchey Super Logic carbon, just need to scrounge €500-odd..... :confused: Found a Fizik Gobi with 7x9mm carbon rails, which I'm pretty sure will fit with the earmarked Ritchey post, but I don't want to commit to it in case I end up with a different post that won't take the oval rails....
Had eyes on a M988 Trail brake set, but that ran away before I could muster the funds, so still on a blank on that front.... :(
For a little diversion, here's #2, The Understudy. It's essentially the same thing as ex-#1 and Project Phoenix, just lower-spec. It"s a "grandpa's axe" kind of mixed bag of parts, directly tracing its descent from my first MTB, a 2008-model Anthem, whilst not carrying any original parts over to the current form..... Although relegated to reserve bike status in more recent years, it was originally my only MTB, and I held onto it because when I was doing long races it was handy to have a backup bike with the same setup.
Frame: 2012 Giant Anthem X1, 6013 aluminium alloy, 18" (M)
Fork: Rock Shox Reba dual air, Pop-Loc remote lockout, tapered steerer.
Wheels: Shimano M785 XT "Race" 559x21mm rims, 9x100 Q/R front, 10x135 Q/R rear, Maxxis Ardent 26x2.25" tyres, toobless.
Crank: Shimano M660-10 SLX 3x, BB71 press-fit Bottom bracket.
R. Derailleur: M663 SLX long-cage, 3x10-sp.
F. Derailleur: M780 XT low-clamp, 3x10
Shifters: M770-10 XT 3x10-sp.
Chain: M981 XTR
Cassette: M771 XT 10-sp, 11-36
Pedals: M980 XTR
Brakes: M775 XT, RT81 IceTech 160mm rotors
Other: Giant in-house aluminium seatpost, Fizik Gobi saddle (Ti rails), no-name aluminium 28.6x31.8x80mm stem, Ritchey WCS Carbon flat handlebar, 710mm x 5° sweep (need a bit more, #1 will get 9°), Jet Black red lock-on grips.
