I've been following a modified version of Rippetoe's Starting Strength (
http://forum.bodybuilding.com/showthread.php?t=998224 or
http://startingstrength.wikia.com/wiki/Starting_Strength_Wiki) routine. As you can see, the core of it is squats, bench presses, deadlifts (Workout "A") and squats, overhead presses and powercleans (Workout "B"). Note that I've substituted powercleans for bent over barbell rows, mainly because I just can't seem to do powercleans properly (and safely). I'm doing a 12, 10, 8 warmup pattern with progressively increasing warm up weights, and then 5 x 3 for the working set.
So here's my routine for Workout A and Workout B:
Workout A
Squats - 12 low weight, 10 low-mid weight, 8 mid weight, 5 x 3 working weight
Bench Press - 12 low weight, 10 low-mid weight, 8 mid weight, 5 x 3 working weight
Deadlift - 12 low weight, 10 low-mid weight, 8 mid weight, 5 x 3 working weight
Incline Dumbell Flyes - 12 x 3
Chin ups / Pull ups - 5 x 5
Dips - 5 x 5
20 - 40 mins running (usually)
Workout B
Bent Over Barbell Rows - 12 low weight, 10 low-mid weight, 8 mid weight, 5 x 3 working weight
Seated Calf Raise - 12 x 3
Dips - 5 x 5
I've been doing this three times a week, either Mon, Wed, Fri or Sun, Tues, Thurs. I'm currently up to session #23 (of 24 sessions in total), so approximately 2 months. I've put on 6-7 kg in this time. I'm taking protein 3 - 4 times per day, 1.5 scoops each. Creatine 20-30 mins before workout, combined with one serving of maltodextrin based carbs to aid absorption (according to the tub anyways......)
Questions:
1. Am I going OK for 6 - 7 kg in ~2 months? I'm currently ~80kg, looking to put on a further 5kg (to 85kg>). Too much weight, not enough, just right?
2. I'm deadlifting 100kg now (inc. the bar)... Is it best to invest in a weight belt before I advance with more weight?
3. Even with squats (85kg), bench presses (60kg) and deadlifts, I'm beginning to strain myself a fair bit. Is this "plateau" normal?
4. Any improvements to the above? I'd like to mix it up a little more... I've been thinking of throwing in Bicep curls, triceps etc every so often. Any other exercise suggestions would be appreciated. Looking to build my chest, shoulders more. Some leg work probably wouldn't hurt either (for my cycling endurance). I need assistance with properly distributing the workouts efficiently such that my muscles have sufficient time to repair.
I will no doubt think of more later!
