Fatman that was said:
Thanks Techno. Getting a spray can today to spray it on so that my cranks
Whoa whoa whoa... a spray can?
That method just sounds like you're asking for punishment! Do it the dipping method, not the spray on method!
How would you know if you're getting even, or even complete, coverage using a spray?
This is how I did it...
1. Get the narrow, cylindrical tin of Plastidip (which is just large enough to fit the oversize crank holders in without touching the sides of the tin)
2. Support your rack upside down on some supports so the crank holders are hanging down and unobstructed
3. Put something on the ground to catch drops of the uber-toxic Plastidip that might drip off.
4. With gloves on (so you don't get that stuff on your skin/hands), raise the tin up underneath each crank holder to dip it in the tin. Maybe hold it there for a couple of seconds so it fills any holes or stuff. Remove the tin by moving it back down off the crank holder.
5. Let the Plastidip dry before applying the next coat. Check the instructions on the tin for proper drying/setting times.
6. Repeat this method several times to apply several coats. This will give you a good, thick, covering of the stuff. I did six coats. 928stu, at the beginning of this thread, did 4 coats.
I would NOT trust the spray to do a good job.... but that's just me....
