Latest eMTB tech
Lost me at cvt lol. But I would have thought that one of the first things to go with a decent mid drive ebike would be the derailleur. Single pivots are the other thing that I would think match an ebike well. When you have more power, you don't really care for pedal bob. It also allows you to run a carbon belt making the back end much cleaner and ditching any sort of tensioning all together.
Assuming the belt holds up. A motorbike style o-ring chain would be better.
Calvin27
The bearings are more the issue. Belt drives require higher tension but from my experience on a commuter, I rekon they'd do ok on a mtb.
The point was however that ebikes haven't really explored what the benefits could be. Simple benefis like getting rid of the rd for example.
Nambra
Sort of where I was going @Calvin27, but why restrict this to ebikes only? Ok, on a non -ebike you might need a battery to run the electronics that governs the gearbox ratio, but that's no different to etap / di2 etc. It's whether the CVT functionality can be separated from the motor that I was speculating on. If so, then it could be an alternative to fixed gear ratio pinion gearboxes on bikes like @Zaf's Nicolai. Instead of rigid mechanical gearing, the CVT plus electronics could give you any virtual gearbox setup you like.
Reactions: Zaf
Zaf
Gearbox Frother
If they can make a Pinion gearbox work, I'm sure a self powered CVT would be possible. It should be simpler once you remove the battery and motor as well, as you only need to put a single power input shaft into the design (instead of both a crank and battery/motor augment).
Calvin27
That would be like a nuvinci. Defniately do-able. My read is that the electronics are there to sell their 'maintain cadence' stuff (effectively like and auto trans?!!).
Reactions: Zaf
