ChopSticks
Banned
You must've missed the part where I mentioned full UST rimsI would think a good wheel builder would be able to lace a wheel in less than ten minutes. Hardly a major labour cost.
Get yourself a tension meter and you can make do without everything else.
I doubt even the best wheel builder in the world can feed in the nipples and lace up a 32h wheel in 10 minutes......
cx rays are bladed spokes...so I will need another tool to hold the spokes to avoid wind up
a spoke key too....it's gonna start adding up, and as I explained before....it's not worth the investment if I only have one wheel set. And if it gets done right I won't have to worry for a few years (hopefully)
that's what I've been reading too.....Thin spokes like CX-rays always round down. They will stretch when bringing them up to final tension.
BUT, do not order spokes until you have the rims and can measure the ERD yourself (at several places and using the nipples you intend to use for the build).
If you need a Sydney-sider to help you out, contact MTBwanabe. I think he's built a few of these with the LB rims.
spokes protruding past the nipple aren't good...esp if I start running out of thread, might be safer getting longer nipples to compensate for shorter spokes (will be a cheaper 'fix') than buying new spokes.
I have spoken to MTBwanabe before...I recall he's based in Richmond Airforce base and offered great prices....maybe I should hit him up given his experience with LB rims!
thanks!!
