Nah, fixed CNC Boost, there's no way you'll see my lazy arse riding Single Speed!Nice.
Sliding dropouts?
Go on!
Say what? I like by head angle "drop adjustable"Are you going for any gusseting around that head tube?
Type A would be my choice tooNah, fixed CNC Boost, there's no way you'll see my lazy arse riding Single Speed!
Seriously though, I've gone with their Option A for headtube gusseting for a cleaner look:
I'm 178cm, but with a slightly longer torso/span (positive ape index), hence the shorter seat tube. I've found my ideal reach for the way I ride is anywhere from 460mm to 480mm, and my body likes 620mm-630mm ETT numbers. Knowing that the ETT and Reach wil effectively lengthen as the fork sags, I've been looking at HT's w/ 465mm to keep it slightly more playful. I've honestly copied most of the geo from the Chromag Primer/Rootdown, but added a bit of chainstay length.How tall are you? Those numbers look similar to what I've played with (mine had a touch more reach).
2025 downcountry spec.Maybe ask for an extra gusset at the bottom of the downtube.
Marino told me he'd been adding one since my failure, but all the frames i've seen since don't seem to have it..
How did the warranty process go?Maybe ask for an extra gusset at the bottom of the downtube.
It didn't, but to be fair I never chased it either.How did the warranty process go?
With one huge flip chip2025 downcountry spec.
Nothing at all? But they knew about it??It didn't, but to be fair I never chased it either.
Very Grim Donut...Maybe ask for an extra gusset at the bottom of the downtube.
Josh Bender huck ?It didn't, but to be fair I never chased it either.
Definitely knew about it. They contacted me after seeing above pic on Instagram and said to send through new geo for a replacement frame, to which I asked whether to send through via email or FB, & never got a response. I had other ideas though and never followed up - ended up with the 2021 Sight frame i'm on now.Nothing at all? But they knew about it??
