About the Silent Hub (Coming Soon) | tairinwheels
Canadian design bicycle silent hub
www.tairinwheels.ca
@PJO next years new wheels
Smith, the motorbicyclist?No way! I want mine hammered out on the anvil by a sweat Smith wearing an apron.
Wow, actual drive train innovation. Great idea, hope it takes off!A Better Derailleur? Supre Drive Splits the Traditional Derailleur in Two
The Supre Drive solves the problem of derailleurs breaking. It’s reliable like a gearbox, but it doesn’t have the drag and weight disadvantages of gearboxes. No other mountain bike drivetrain achieves this: the reliability of a gearbox combined with the efficiency and low weight of a derailleur...www.vitalmtb.com
I’d take a gearbox 1000x over this though.Wow, actual drive train innovation. Great idea, hope it takes off!
This is pretty cool, has managed to bring some of the advantages of a gearbox to an otherwise conventional system. I think the big win is the chain and derailleur clearance from the ground and no clutch! Otherwise it's only a small win weight wise at the back wheel, still think gearboxes is where we want to get to ultimately. Can't wait to get some proper reviews on the Effigear Mimic, still bugger all real world data on itOk this is pretty cool.
I disagree with you here, there is a requirement for one additional mount to run his derailleur. If you ran the SRAM UDH you’d be able to run a conventional one as well. The tensioner jockey would mount to a frames ISCG mount so there are no other mounts to introduce.I think it's a great idea, but wouldn't buy it. Even if it works flawlessly, it still requires a frame specifically designed to accept the parts. Likelyhood of many manufacturers jumping aboard enough to make this commonplace? 2/5ths of f***-all...
At least with a gearbox, you can swap it between compatible frames, and they allow a lot more packaging options for different suspension designs.
I do think this would be a remarkable leap forward for downhill or "super-enduro" type bikes though given (IIRC) a derailleur-based shifting system is a UCI requirement for World Cup racing.
Personally - I reckon if a derailleur bothers you that much, a gearbox is a better solution.
You might have seen Deviate Cycles' first bike in 2017, the 160mm-travel Guide that employs a 12-speed gearbox from Pinion and 27.5'' wheels. It's a wild-looking carbon fiber thing with swoopy tubes and, much like the new Highlander, a high single-pivot suspension layout. The longer-travel Guide (pictured here) is intended for enduro-ish riding, or even lapping the bike park, where the focus is on the descents and there's a case to be made for the reliability and suspension performance that a gearbox can offer.
But if you've used a gearbox before, any company's gearbox, you'll know that one thing they don't offer is efficiency. ''We're sold on the gearbox for a winch up/tear down kinda riding, and the suspension performance and low unsprung mass it offers is frankly incredible,'' Deviate's Ben Jones said of their Guide, although he's far more pragmatic about gearboxes than you'd expect given that 50-percent of their model range uses them.
''However, for our trail bike, the gearbox had to go - it feels draggy during undulating riding or when accelerating hard,'' he continued.
The concentric rotating tensioner isn’t the issue, it’s fitting the high idler sprocket and making it work in the suspension design. A couple a mm here and there can have really significant effects on how a bike rides so it’s not just slap an idler anywhere and she’ll be right.I disagree with you here, there is a requirement for one additional mount to run his derailleur. If you ran the SRAM UDH you’d be able to run a conventional one as well. The tensioner jockey would mount to a frames ISCG mount so there are no other mounts to introduce.
having put some time on a zerode the biggest drawback is being unable to shift under any sort of power. I can shift under full power on deore drivetrain ffs! Also the drag is more noticeable than any idler bike I’ve ridden ( a Kavenz, commencal and norco)
Sorry, I misunderstood your previous post. I thought you were referring to usability of his drivetrain on different frames being limited.The concentric rotating tensioner isn’t the issue, it’s fitting the high idler sprocket and making it work in the suspension design. A couple a mm here and there can have really significant effects on how a bike rides so it’s not just slap an idler anywhere and she’ll be right.
I think this has some really practical applications (like downhill racing) but it’s unnecessary for most people’s riding.
To be fair, I was also saying that. It’s another derailleur mounting standard (in its current form), and rear swing-arms will have to have the internal space (or a raised arm) for the derailleur to fit through. A Sram UDH could be incorporated into the derailleur mounting though like you say.Sorry, I misunderstood your previous post. I thought you were referring to usability of his drivetrain on different frames being limited.
Not me personally but a friend managed to lose 3 at Stromlo and the remaining were loose too. Only time I’ve seen them loosen before.A cassette tool and wrench aren't the kind of things you take on the trail though. That said, how many times have you had to tighten rotor bolts on the trail?
They must have been loose to begin with perhaps?Not me personally but a friend managed to lose 3 at Stromlo and the remaining were loose too. Only time I’ve seen them loosen before.
I’d assume they were. Point still stands that I’ve seen the need to tighten bolts once in my riding life.They must have been loose to begin with perhaps?
Who would not notice rotor bolts being loose?They must have been loose to begin with perhaps?
Someone having too much fun until it all goes horribly wrong!Who would not notice rotor bolts being loose?
Its getting there with the UDH (Universal Derailleur Hanger)One part of a bike that will never have a universal standard is definitely a derailleur hanger. I think he chose the perfect part to have proprietary mounting.
