DMan
LolJust acknowledging there might be differences in the technical subtleties of catch cans with cancer mobiles as opposed to their use on (less cancerous) DI petrols.
That is true.
You like sniffing unleaded petrol fumes at the sevo instead.LolJust acknowledging there might be differences in the technical subtleties of catch cans with cancer mobiles as opposed to their use on (less cancerous) DI petrols.
You like sniffing unleaded petrol fumes at the sevo instead.![]()
I'm running one of these, seem to do the job reasonably well on my old diesel navara. I've got a Gatorade bottle set up underneath to catch the run off, I reckon I'd get around 300ml every 10,000km service cycle so it's definitely saving some build up. It doesn't stop all the oil getting through though, there's still residue on the intercooler pipes but I'd hazard a guess that it's less than I'd otherwise get. Didn't notice a difference between metal mesh and fabric, both seem to do the same thing but metal can be washed and reused.Looks exactly like this though? I'm not trying to be cheap, just curious.
https://www.ebay.com.au/itm/Oil-Cat...573471?hash=item3cf8584a1f:g:Ey8AAOSwE95aXEM4
The beast has a solid 545,000 on the clock though so your results will probably be different id be willing to bet...
Sent from my E5823 using Tapatalk
Hey Dman have you checked to see how much oil it goes through in between services?
What a lot of you blokes don't realise is that the car is tuned to cope with oil vapours as part of the emission control system, Fair enough if the car has a serious problem with piston blowby but I wouldn't put a catch can on for the sake of it. I can tell you now it will not stop gas reversion from valve overlap depositing carbon gunk on the back of the valves. The only thing you can do there is use fuel additive cleaner from the start of owning the car.
https://www.outbacktravelaustralia.com.au/4wd-mods-powertrain/diesel-fiddles-may-2016
Yeah, the Subies use the foam. It's best to use it in regular intervals from when your car is new as once you get a thick coating of carbon it takes a lot to get rid of it. I was sceptical of upper cylinder cleaner until I removed a few cylinder heads that had it done regularly and they really looked clean in behind the valves and ports. I've had good experiences with the Wynns branded cleaner.Or upper engine cleaning foam
I had a Japanese made one years ago, sprayed on carbon build up on old pistons I couldn't get off with a blade, 5 mins later would float off.
Three-bond?
There are also differences between the particulate exhausting heavy machinery diesel most cancer studies are based on versus the more efficient and modern car engines. What's better, a large petrol guzzler versus a smaller turbo diesel with the same power output but more efficiency?LolJust acknowledging there might be differences in the technical subtleties of catch cans with cancer mobiles as opposed to their use on (less cancerous) DI petrols.
He's got no respect for our old Hiluxes that we save from smelting into new Alfas.There are also differences between the particulate exhausting heavy machinery diesel most cancer studies are based on versus the more efficient and modern car engines. What's better, a large petrol guzzler versus a smaller turbo diesel with the same power output but more efficiency?
Note the lack of acronyms, particularly the one used for the internal combustion engine, using that acronym will end up with the Facebook data machine labelling me a drug addict. You can expect some police surveillance soon!
I'd rather stand behind a diesel and suck in raw diesel fumes than stand behind a petrol with the cats that aren't working properly, which is a lot of petrol cars on the road of old age.
I can tell you from working in fairly enclosed workshops when motors are running, which one will make you cough your guts up first and make your eyes sting, What a lot of car companies don't tell you is that emission controls hardly work when a car is warming up in it's overfueled (rich) condition. You know, the time people are running around their car in an enclosed garage filling their boot or loading the kids in the car with the motor running. Breathing in raw unleaded fumes is not ideal.I can point you in the direction of a good Oncologist...
and you’re right - I have no respect for old diesels being used as general transport. Also no respect for anyone who buys a new one either - you can’t plead ignorance as you might on the old one you bought years ago.
I was only having a bit of a joke but,
I will like to see a true evaluation on the environment with deposing of old used cars, I know with mine over 32 years old and most people I know these days change their cars in under 10 years periods. Big truck engines that are under constant loads and you can see large plumes of smoke come out of the stacks when they accelerate would have been more of a worry to me.
Most of these high powered cars like Holden 6L utes on the roads that have been retuned with big cams are no different to an old car.Over the years I've put a fair few cars on gas analysers and a lot of cars pour hydrocarbons out of the tail pipe when accelerated. Governments hardly ever check emission control on cars that are few years old and when they do the tolerance is really loose from what I've seen in QLD. They just go after some car enthusiast that drives his muscle car once a month while the soccer mum car has leaking exhaust fumes with clogged up fuel injectors and the cat needed replacing about about 5 years ago.
I'm not a big car driver these days, I've only put about 60k on my hilux in the last 10 years and the wrx virtually sits in the garage most of its life.
