This.Washers under the adapter.
Buys ebike, won’t buy a $10 adapter. Sounds legit.Thanks, washers it is then. I may have trouble finding some the right thickness so will just modify or make some if need be.
I just did not want to splash out on extra adapters ect. 203mm rotors seem more common than 200mm
$3! Didn’t you read his post in other thread, lamenting the cost of running an Ebike. Or was that @outerlimits? I tend to confuse him, I mean them...no, him.Head to bunnings with brake caliper bolt in hand. Go to metric bolt section, find a packet of brass machine washers, the are about 0.5mm thick. Spend $3 on packet.
The belt in my motor is recommended replacement is at 15000km. The battery recommended replacing at 700charge cycles, but should still retain 75% capacity after 400 cycles.
I have done 2500km, 55 charge cycles, battery capacity at 95%.
On the 3rd set of brake pads, second set of tyres, chain number 6 and cassette number 2.
Definitely pitfalls to owning a ebike and it’s probs why I would Bork at buying a $10 component if I did not have to.
I don’t think they would help, but maybe worth a try. I see KTM make both moto and mountain bikes. And Magura make brakes for both, and ohlinns I think that’s what they called make suspension for both. But they have a bit of a recall situation on their Mtb forks at the moment.Maybe try a motorcycle forum for braking information more in line with your "riding" preferences.
I give zero fucks. You ride a motor bike and pretend it's a mountain bike, so your input is about as valid as whoever it is that runs the local supre.I don’t think they would help, but maybe worth a try. I see KTM make both moto and mountain bikes. And Magura make brakes for both, and ohlinns I think that’s what they called make suspension for both. But they have a bit of a recall situation on their Mtb forks at the moment.
Thanks for taking the time to comment. You can put it into whatever box you like that’s your prerogative, and you have the right to your opinion. It does have a motor, and is a bike, so you a very well entitled to call it as such.I give zero fucks. You ride a motor bike and pretend it's a mountain bike, so your input is about as valid as whoever it is that runs the local supre.
Yeah, I agree with this being not the place to bring up ebikes. It was a thread I posted about brake rotors, with no mention of ebikes. ( they share the same rotors as hooman powered bikes after all ) some 1001 level troll must of brought it up, they may of even referred them as motorbikes. Forgive me if I’m wrong, i’m Trying to use language that is familiar with you.You @Kind_cir underestimate my prick levels...you have a special section of the forum for discussing your shit heaps, something that was specific designed to appease your wringing and crying about not being accepted as a mountain biker. As a sign of gratitude to those that have provided you such a space and to those who have accepted the sanctity of that section, how about you stick to that? I've been polite enough to not pollute that section with my thoughts at the risk of upsetting you and your other weak arse looser comrades, a little courteousness in return would serve you well. In the mean time believe and dream all you want. You're a boring yawn and I'm certain that you only have an account here to either spruik e-bikes because you have a vested interest in them or you're a 1001 level troll.
Also...you say trail development, I say trails I have freely ridden for a long time are being destroyed by selfish incompetent dickheads such as yourself. The new breed of trails are also mostly boring and bland events designed so useless cucks can power along them and feel something. The same cucks who don't turn up for build days.
Yeah, seen a few harp on about him, and not understanding, I had a bit of a look and read.And the last person to use that spelling was... outerlimits.
And there it is, folks.
Well, could be, I've never see @uncle grumpy and @moorey in the same room either, hmmm....Pretty funny really... maybe Moorey is Grumps, ooooh such a mystery.
C’mon Grumps, I know you don’t mean that.And.... ignore.
