Good to know, 10mm all around. No idea on the weight but its pretty light even with the tube compared to the fork springs. Not that I'm concerned about fork weight on an eeb with a DD Assegai on the front anyway.
I've had my 38 air spring apart, pulled the guts out of it and added the Luftkappe.
The footnut needs to be heat gunned anyway to melt the loctite, then slide the inner out, you cant get the air spring piston out/off without removing the footnut first.
That's why I made the ghetto tool to slide the air shaft back through the seal. The edge of the shaft where the footnut screws into is sharp as knife and will fck the seal on the way through without a taper.
We camped there and rode Melrose for two days, maybe 6 or 7 years ago, when we were on the way up to the centre. It was fun for sure, but it was difficult to know where you were, or where you were going. Yep, lots of connecting roads and stuff. One ace ride was in some farm where the cocky...
www.rotorburn.com
