treble
anything that would work with a Sram 11 speed derailleur.Depends on if you have SRAM or Shimano Cassette in mind.
You can use an 11 speed Shimano cassette. It will work with either Shimano or Sram 11sp derailleurs.Can i put an 11 speed cassette on my 10 speed (sram x9) rear hub?
probably a stupid question...
250PSI maxDoes anybody know what the max psi is for a cane Creek double barrel air? One of my chums is up for a new shock (old SC Bullit) and given my positive experiences with said shock I've recommended he get one (performance and weight drop for the old donkey). He is a larger rider, so would like to know the shock is up to the task before he throws some coins at it.
Thanks. I suspect a coil option may be the go.250PSI max
I dunno, it's a huge can that doesn't usually need a lot of pressure to achieve sag. A quick google shows that most Knolly tunes recommend 175PSI for about a 220lbs rider; obviously give or take a little depending on the leverage rate of the frame.Thanks. I suspect a coil option may be the go.
220lbs...ok this could work. Im estimating rider weight around 120-130kg. I may have to hit up a certain suspension workshop and ask their advice.I dunno, it's a huge can that doesn't usually need a lot of pressure to achieve sag. A quick google shows that most Knolly tunes recommend 175PSI for about a 220lbs rider; obviously give or take a little depending on the leverage rate of the frame.
104bcb...should do the trick. Remember to buy some single ring size chainring bolts as well.Currently running stock deore 2 x front chainrings, deore cranks (2015)...
Would this chainring be a straight bolt on fit (or minimal hassle at least) to go 1 x ??
http://www.chainreactioncycles.com/...rrow-wide-oval-single-chainring/rp-prod131089
No worries. Make sure the bolts are sexy and bling...crc has plenty on offer.Thanks poodle!
Purple! Half the weightNo worries. Make sure the bolts are sexy and bling...crc has plenty on offer.
And twice the RRP when flipped.Purple! Half the weight
Don't need to worry about the bolts. The two rings on a 2x are bolted independently, so you're effectively just swapping the big ring.104bcb...should do the trick. Remember to buy some single ring size chainring bolts as well.
Its to hang them on a nail on your shed after taking them off in favour of shimanos.quick question, what the fuck is the prongie looking bit on the handlebar mounts for, cant work it out. Bottom image is what I am talking about.
Bark buster.quick question, what the fuck is the prongie looking bit on the handlebar mounts for, cant work it out. Bottom image is what I am talking about.
E bike throttle cablequick question, what the fuck is the prongie looking bit on the handlebar mounts for, cant work it out. Bottom image is what I am talking about.
