treble
Depends on if you have SRAM or Shimano Cassette in mind.
anything that would work with a Sram 11 speed derailleur.
You can use an 11 speed Shimano cassette. It will work with either Shimano or Sram 11sp derailleurs.Can i put an 11 speed cassette on my 10 speed (sram x9) rear hub?
probably a stupid question...
Does anybody know what the max psi is for a cane Creek double barrel air? One of my chums is up for a new shock (old SC Bullit) and given my positive experiences with said shock I've recommended he get one (performance and weight drop for the old donkey). He is a larger rider, so would like to know the shock is up to the task before he throws some coins at it.
250PSI max
Thanks. I suspect a coil option may be the go.
I dunno, it's a huge can that doesn't usually need a lot of pressure to achieve sag. A quick google shows that most Knolly tunes recommend 175PSI for about a 220lbs rider; obviously give or take a little depending on the leverage rate of the frame.
Currently running stock deore 2 x front chainrings, deore cranks (2015)...
Would this chainring be a straight bolt on fit (or minimal hassle at least) to go 1 x ??
http://www.chainreactioncycles.com/...rrow-wide-oval-single-chainring/rp-prod131089
Thanks poodle!
No worries. Make sure the bolts are sexy and bling...crc has plenty on offer.
Purple! Half the weight
104bcb...should do the trick. Remember to buy some single ring size chainring bolts as well.
Its to hang them on a nail on your shed after taking them off in favour of shimanos.quick question, what the fuck is the prongie looking bit on the handlebar mounts for, cant work it out. Bottom image is what I am talking about.
E bike throttle cablequick question, what the fuck is the prongie looking bit on the handlebar mounts for, cant work it out. Bottom image is what I am talking about.
