Ummmmm sure why not?So the top crown holds it on and all the top cap does is tighten the headset. Still hoping I haven't fucked myself again.
The steerer could effectively be level with the crown when tightened and be cool
If you don’t leave a little, you risk squashing the steerer when you tighten crown.So the top crown holds it on and all the top cap does is tighten the headset. Still hoping I haven't fucked myself again.
Going to try and have another go at the GT tomorrow, test it with the complete headset on. If success has happened I will then get a dm stem.If you don’t leave a little, you risk squashing the steerer when you tighten crown.
You know to preload headset on dual crown forks with clamp bolts loose on both crowns? Many don’t, and wonder why they have loose headsets no matter how much they tighten top cap.
I misspoke. Lower doesn’t need to be loosened to preload headset,Going to try and have another go at the GT tomorrow, test it with the complete headset on. If success has happened I will then get a dm stem.
I misread what you said about the crowns and thought "durrr". Then reread it and realized that makes sense. So lower crown loose as well.
Even at my age I continue to learn, cheers
Word upBut where the top crown clamps onto the fork legs does...
Now available at MTBDDumondetech pro x. Often it's rebadged as Stan's.
<1 year means new so pay new price + covid tax, >1 year means it is a fucking classic, pay more than new price + covid tax.What the absolute fuck is "Used for <insert amount of time here>" (eg Used for 1 yr) meant to mean on bicycle ads - Does time frame now determine the suitability of the parts to do what I am needing or reflect the quality?
Take it back off & work out why! Measure between the two.OK, I've whacked a 10 speed cassette on a wheel that had 8 speed. Tighten up and there is a mm or 2 of movement, is this normal, what have I done wrong.
Will this affect my riding enjoyment
Yes.OK, I've whacked a 10 speed cassette on a wheel that had 8 speed. Tighten up and there is a mm or 2 of movement, is this normal, what have I done wrong.
Thickness: 1.85 mm
Application:
Manufacturer Part Number: Y-4T724000
- using a 8-/9-speed cassette (Road) and an 8-/9-/10-/11-speed cassette (MTB) on an 11-speed (Road) freehub
- using a 10-speed (Road) cassette on an 11-speed (Road) freehub (1.85 mm + 1 mm)
I have and it's always been random as to the cassette/ hub combo. Just pays to have a couple to .5mm shims in the sparesWhat is this witchcraft? Never in my life needed additional spacers for a hg cassette on a hg hub....assuming that’s what you have.
Haven’t left out a spacer between the loose cogs? Or you haven’t turned a 10sp into a 9sp accidentally?
