Can someone measure the thickness of a formula rotor for me?
Ive ordered some cura 4s but they are out of rotors so looking to run some swiss stop catalyst rotors.
What size (diameter) rotors are you after, pretty sure I still have some of the thicker (newer) Formula rotors at home that only saw very light use...
Was after a 203 and a 180 6 bolt.
Winner winner, brake rotor dinner. Pre-scrubbed in for your convenience! (I don't have the screws though, NFI where I've put them...)
372076
I always though they were thicker for some reason (like 2.0mm+)...
I just went and measured the ones I have and they're all 1.9mm
The Hope floating rotors are 1.8mm
My conclusion: the Formula "Monolithic" rotors must be made out of some magical non-bendy material then - because all my Hope rotors have always slightly warped after each ride (I run my brake pads really close, so any warpage is quickly evident), but the Formula ones always ran dead straight.
Are the hopes floating?
Yep, probably 6 or seven different rotors. They've all done it. They don't warp horribly and you don't feel anything when braking, you just hear the faint brake rub.
Just floating rotor things. Shimano floating jobbies don’t warp much because they aren’t “proper” floating rotors. The pins are too tight.
I hope so because the rotors I have at the moment are annoying! I still haven't put yours on yet.
How are Bike Shops not rolling in money? - I swear every bike listed for Sale in the country uses either
  1. Just serviced
  2. Regularly Serviced
And WTF do people call a service? I lubed the chain?
Writing these down for when I sell my next bike
I don’t have bookface so can’t see the add. I wouldn’t if you want to go 12 speed though.
They are old and had tonnes of use - but price was reflective of that - I don’t see an advantage to the cranks other than buying them because you want them - always a valid reason in my books :)
