Try PM'ing Udi.Anyone know where i can get shims to suit a DHX RC? .252" ID are like unicorn shit.
Shims...just so we are on the same page, are you referring to the mounting hardware? Sometimes called reducers? If so I would email your preferred online retailer, especially one with a good rep for suspension (eg NSD or TBSM) and ask them for some. Likely they can hook you up pretty quickly.Anyone know where i can get shims to suit a DHX RC? .252" ID are like unicorn shit.
Wrong page. Turn to the page headed "shims".Shims...just so we are on the same page, are you referring to the mounting hardware? Sometimes called reducers? If so I would email your preferred online retailer, especially one with a good rep for suspension (eg NSD or TBSM) and ask them for some. Likely they can hook you up pretty quickly.
Google has mislead me...Wrong page. Turn to the page headed "shims".
Hey team
Springs for rear shocks:
If my calculated Spring rate is between 350-375, am I better off going for a 350 Spring and winding on it a bit (preload?) or better just going for the 375 spring hope it's not to hard?
Does winding the spring in effect increase its Lbs number/rating? Example, if I have a 350lbs Spring, and I wind it around twice, does it make the spring, say, a '365lbs' Spring?
Hope it makes sense....
Thanks,
Maybe I should put this in the stupid questions thread.......
Thanks for the responseWay back when Moses rode bikes...the dude that used to do suspension work for fox at dirt works (Bear) had.an article in mtba mag. He was adamant that you shouldn't tighten your shock springs very far. Like 1 or so turns from memory...so depending on the shock I would be wary just ramping up the spring.
If a simple shock (eg fox vanilla style thing) i would get the heavier spring. If it is too hard, drop back. Ideally get both and try them or at least measure sage etc in the shed...
If a more complex shock (eg a fox rc4) i would go lighter and then use the air and compression features to fine tune the ride.
I've had 2 of those. I would run the lighter spring and pump in some air.Thanks for the response
It'll be a DHX2 with SLS Spring
if your "calculated" spring is determined by your weight then i would definitely want to try both to get the appropriate loaded sag without adding too much additional preload, preload is a good way to fine tune a shock that suits your weight getting sag exactly where you want it of course, but too much preload will reduce your shocks effective travel, it may also cause the spring to bind causing the rear to feel harsh and over sprung, where in fact it's too softly sprung, preload has compressed the spring too far and your compliance and travel are limited.Hey team
Thanks,
your septic system.what do you mix Bacardi with ?
Ice, limes, caster sugar, mint and soda or tonic water.what do you mix Bacardi with ?
Clickbike......Does anybody remember the web site dirt works (importer) were using to clear out their old stock please?
