ここには見るべきものは何もありません
Is Bob your uncle too ?
Father, grandfather, and great grandfather...perhaps.
Ha! So very true, I get a bit of vertigo thrown in for good measure.What is it about the human brain, that when you step onto an inoperative escalator, even though you know it's not moving your body still compensates as though it is? Then climbing what should feel like normal steps it feels like you're wading through water. Then alighting at the other end your body compensates again.
And when you see the elevator and you know you want to go up it your brain and body react in dread the moment you realise it's not working and you start looking for alternatives.Exactly. That weird sensation that you're toppling over. Stupid brain.
I believe so. So far as I know, gxp is the same spindle regardless of the BB it's inConfused over BB sizing.
I've got a SRAM (X1 1200) crankset that I've taken out of a GXP 92 BB. I want to put it in a 73mm threaded BB. Is this possible if that BB is also GXP?
What do you need @Tubbsy I have the Shimano external bottom bracket tool if that's what you need.
I think thats where I've got to too from some reading, thanks for that!I believe so. So far as I know, gxp is the same spindle regardless of the BB it's in
I just have the spanner so it won't work with the torque wrench but your welcome to it if you need it.Yeah just for XT. I have a centrelock spanner which might fit but figured it would be good to have the socket thing to attach to the torque wrench for getting it back on.
I'm going to replace the frame bearings and the chain ring is in the way.
Might get away with just removing the crank arm, but I'll let you know. Thanks for the offer.
Thanks all good for the spanner. No doubt the fuckwits thread awaits next week...
Do you mean one of these?Why is every Australian online bike shop out of stock on the one bottom bracket tool size that most people need?
as long as the polished sections of the axle where the bearings sit are seated on the inner bearing race, should be golden..Confused over BB sizing.
Looks like a BBQ at my jointWhat the fucketty fuck???
