I’m all about Rimpact. Easy to fit, way lighter than CC but still actual meaningful rim protection compared to the little flat strip style ones. I bought a mixed set and have the Pro in the back of the enduro bike and Classic or whatever it’s called in the back of the XC bike - even easy to fit in a 2.25” XC tyre.Tyre insert with the easiest installation? Mainly for rim protection.
CushCore? Turbolight? Tannus? Rimpact pro? All the same shit?
apart from weird sizes (13x15xt, 8.1x11.1xt), anything special about them? nylon?Where to buy Fox fork crush washers without having to buy bulk?
I get mine from army disposals.Can someone suggest where to buy decent shoe laces? Paid $5 at rebel and they lasted about 4 uses before the outside snapped leaving the skinny bit in the middle. Looking for non stretchy ones.
Grunt 3.5mm x 5m Black Starter Cord - Bunnings AustraliaCan someone suggest where to buy decent shoe laces? Paid $5 at rebel and they lasted about 4 uses before the outside snapped leaving the skinny bit in the middle. Looking for non stretchy ones.
Where do you get the aglets?
Don't know, through you can buy them it seems but I'd just persevere with threading through without the aglets. Only gotta do it twice (2 shoes)Where do you get the aglets?
Gravel ok? If so, there's lots of good stuff around St Albans and Wiseman's ferry up into the hunter.where to go for a short riding getaway from sydney - wife is a roadie so something suitable with quiet roads maybe 60-80km a day?
Bootlace crimps?Don't know, through you can buy them it seems but I'd just persevere with threading through without the aglets. Only gotta do it twice (2 shoes)
past st albans its probably a bit much. might try and make another day out where we park at wisemans ferry and go back via webbs creek. only a short stretch of gravel that way. did a road trip down the princes hwy recently and was rather taken with the idea of the east gippsland rail trail and others for short breaksGravel ok? If so, there's lots of good stuff around St Albans and Wiseman's ferry up into the hunter.
Heat shrink tube worksDon't know, through you can buy them it seems but I'd just persevere with threading through without the aglets. Only gotta do it twice (2 shoes)
Been using Huck Norris for a few years. They have a few varieties depending on your riding flavour. Easy to install and they work.
I’ve only used Huck Norris originals and Cushcore.
Rimpact do a super duper job, don't weigh a ton and are easy enough to install as long as you remember to use the centre channel and some diluted washing detergent.
Thanks all for the suggestions! I ended up getting a Tannus Armour, found it for $69 at bikeonline Installation was toooo bad. Hardest part was the last few cm's and massaging the tyre+insert so there is no wobble etcI haven’t used them yet, but I have heard the Vittoria liners are good for rim protection and are easier to fit than cushcores.
They're more for anti-theft, you're meant to use a torque wrench on them also as the thread strips easily if over-tightened.Well hello peeps, I have a couple frames with horizontal dropouts.
Would these stop the dreaded wheel slide in the frame when breaking heavily.
Qr sucks in them so wondering if these would work like better. Thanking you for any help
Halo Hex Key 100/135mm Bolt-On Skewer Set Front/Rear Road / Track Bike PURPLE | eBay
Stainless steel skewer. 15x3mm cone spanner recess cut into nut, just in case the tab cannot operate. The "Nut" features a steel Halo "no-turn tab" to help make it easeir to tighten or loosen the hex through-bolt.www.ebay.com.au
