The only time I've ever dropped a chain on my SS was when I ran a SRAM PC1 chain. I fitted it before a 12hr race and it come off 4 times during the race! I figured it was due to running a 1/8 chain on sprockets designed for 3/32 chain (although sram claim it works and the shop I got it from highly recommended it for my setup). If you check it on the sprockets it has a lot of side to side float.Howdy. Earlier this morning, I managed to drop the chain on my Highball SS. I have no idea how it happened nor even where to begin looking for reasons so thought I would ask youse guys for advice.
- My chain ring is 36t Shimano Zee, sprocket is 19t surly
- Chain itself is SRAM PC1 SS chain (I think)
So if any of you have dropped the chain on your SS or if any of the above looks to be the likely culprit, let me know.
Thanks
RDH
Another option might be a KMC Z610 HX. Have used these on a few bikes now, very strong chains.A stick eh? Hopefully, that is the case and I haven't scored myself a chronic issue.
Also, I will look into the Izumi 3/32 chain.
That would be a chain tensioner / chain tug to stop the axle slipping forward under power. Worthwhile for slot dropout frames with QR skewers. If you don't have a chain tug then quality internal cam QR skewers (like shimano) tighten heaps better than cheap/light/colour matched open cam skewers.Edit: apologies for the outrageous newbie question, but what is it that you guys have attached to the rear QR skewer that is covering the dropout, and why is it needed? I've got the slot dropout frame and I was just going to use a standard Ritchey QR skewer...
Thus guy's spot on, although even with shimano skewers I'd be running tugs, pulling a wheel sucks.That would be a chain tensioner / chain tug to stop the axle slipping forward under power. Worthwhile for slot dropout frames with QR skewers. If you don't have a chain tug then quality internal cam QR skewers (like shimano) tighten heaps better than cheap/light/colour matched open cam skewers.
Cool, thanks guys. Now I just need to work out which tugs to get. The DMR set can be had for a good price, but do I want 10mm or 14mm?Thus guy's spot on, although even with shimano skewers I'd be running tugs, pulling a wheel sucks.
You'd never tell the difference just from riding - they're incredibly stiff for something with only one leg. And almost no stiction - conventional forks feel terrible (stiction-wise) by comparison.I can't get over how strange those lefty forks look. Does it feel much different to a 'normal' fork?
On one make a setCool, thanks guys. Now I just need to work out which tugs to get. T
Yeah, but then I have to wait for it to arrive from the UK. Would rather a locally-sourced one, might check out my LBS.On one make a set
On-One Chain Tugs in Australia - http://www.raceworx.com.au/products/OnOne-Chain-Tug-(for-Quick-release).htmlGreat Inbreds guys. I should be finished my Inbred build in a day or two (Fire Engine red). Then we can have a whole Inbred family!
Hmm, that doesn't sound right.
badtreefrog, I'm liking the green frame. Be good to hear how your 'dingle speed' handles on the rough stuff.
Awesome, thanks for that. Forgot that Raceworx stock On-One gear (I ordered my frame direct from Planet X in the UK, was thinking I'd have to order the tug from there too).On-One Chain Tugs in Australia - http://www.raceworx.com.au/products/OnOne-Chain-Tug-(for-Quick-release).html
They recommended only using one, so I am only using one - less fiddly, especially with the two ratios.
Mr626, in theory the dingle speed should handle exactly the same as a single speed off road, it is how my quads handle the hills that is the question!!
Brisneyland - Nice! Mine is certainly no lightweight but the way i see it the heavier it is the fitter I get!
I gained a new mate out of that trade so it was worth every dollar and more.Awesome, thanks for that. Forgot that Raceworx stock On-One gear (I ordered my frame direct from Planet X in the UK, was thinking I'd have to order the tug from there too).
I like your thoughts on weight and fitness also. My Inbred will tip the scales at around 13kg when done so no lightweight either.
Stinky, as much as I like Coopers I think I would part with a case for a deal like that
