The stupid questions thread.
Is it a cap over the rebound knobs? Current Fox 36 have that setup.
Shouldn't have any "clicks" when turning if so...
Hmmm. Cheers mate. No clicks ... do I just pull it down, or is there more to it?
^ Give that man a gold star.
359530
Upon seeing this photo of a South Korean persons ski suit being worn to fend off Coronavirus 2019-nCov, i straight away though of bikers wearing DH helmets in public.
Poodle, surely you can get us a photo from on the Tokyo underground wearing your TLD helmet
Japanese commuters have worn masks for a long long time, since the early Edo period when the subway was largely horse drawn conveyances. The masks were mostly to filter out the obnoxious effluvium from horse farts.
The masks and attitude of those wearing masks will be sufficient deterrent for any airboene virus.
Thank god! I should be ok if I keep my mask zipper closed then you're saying??!!
Without the ball gag should be ok. Pretty sure there was a survey a while back which debunked the usefulness of basic masks against virus infections. Or not.
The loose fitting ones most people have offer some protection from large particles sprayed at you by a sneezer. Airborne particals can get around the sides though. They also likely help sick people from spreading disease.
Hazmat suit for the win.
If I were to buy this, could I use a cog from my cassette to swap with the 16T it comes with?
359708
359709
View attachment 359708View attachment 359709
Depends on your cassette. A lot of older 8 speeds could be dismantled, but not so much with newer stuff.
Also much better if you use a proper single speed cog. Unless you have a steel freehub, the cog will eat into the freehub, and the teeth on a cassette cog are shorter and ramped so won't hold a chain as well.
And I've found the spring loaded tensioners far more reliable than static ones. Could just be me, but I've found the static ones just don't hold the tension right and can loosen off where springy ones adjust themselves.
Sent from my F5321 using Tapatalk
