Yep - spin the seatpost clamp to matchThey’re some stout looking seat stays and chain stays. I reckon having the split in the seat tube facing forward is good - less likely to get mud splattered into it.
You animal, that's some sort of hate crime.Yep - spin the seatpost clamp to match
Don’t look closely at my bikes thenYou animal, that's some sort of hate crime.
Haha, +1.They’re some stout looking seat stays and chain stays. I reckon having the split in the seat tube facing forward is good - less likely to get mud splattered into it.
Cheers mate, I'll see if I've got some delrin lying around to make a spacer with - that's not a bad solution. Not sure about the 38mm though!Something like this might work..
Think they went with 38mm because of bad cable rub issues.. Probably only need a loop long enough at full compression..Cheers mate, I'll see if I've got some delrin lying around to make a spacer with - that's not a bad solution. Not sure about the 38mm though!
Supposedly you get much more even clamping force if the clamp bolt opposes the split, therefore, front split, rear bolt.Haha, +1.
I was thinking the same thing!
The bird clamps are designed for the split forward and look/work well. No dirt in the seat tube is great!You animal, that's some sort of hate crime.
