blacksp20
Unless you are having a crack at a WC Downhill Event or EWS you probably don’t really need triples.
I most definitely am not.
Brains trust, can I run some numbers by you please.
I've punched my numbers through prowheelbuilder and DT and got similar numbers for required spoke lengths.
Front 290.4 L and 291.9 R - DT recommended 290/292
Rear 291.1 L and 289.9 R - DT recommended 291/290
Would there be an issue if I went with 291 all round to simplify things or should I stick to the recommended lengths?
Will be using SAPIM Race spokes with SAPIM brass 12mm nips and using washers supplied with rims.
