run 'em lower than others. Less tread actually means more rubber on the track, and less gaps between tread.I find that so hard to believe but I've read it so many times that it must be true.
Without any significant tread I just can't understand how they could be as good as people claim.
Perhaps its the rubber compound.
anyone that calls us.Who stocks the Ravens in Melb?
My personal experience with Race King 2.2 (had to run tubes, as I simply couldn't get them to work tubeless) was that they have a fair bit of rolling resistance.Hi Guys,
I'm just new to the 29'er world after purchasing a Kona Unit. They come stock with Ignitors so I'm looking to getting something with a lower rolling resistance. I've read the reports on the Xking and Race King but haven't seen comment about them being on the front or back when reviewed.
I'm considering running RK back and XKing front, what are people's thoughts? As a bit of context, I'm a regular weekend warrior along the Yarra mainly and would be commuting as well (maybe 100km a week) and run tubes.
Cheers,
Coaster
I'm not sure you'd be willing to consider Schwalbe but the 29 x 2.25 Racing Ralphs offer a nice mix of grip, comfort, and speed. They are expensive. I know you mentioned that you'd run them with tubes but the 2011 Schwalbes are tubeless ready, meaning the tire has a safe bead if you ever choose to head down that path.Thanks Bodin. I appreciate the information and will scrub that idea. If I wanted rolling resistance I'd keep to my Ignitors! I've grown to love Conti's for some reason, but use an Aspen front and Monorail back on my 26" Anthem so was looking for the Conti equivilent just as a trial. XKing looks good.
Cheers and thanks,
Coaster
I installed my 2011 2.25 x 29 Snake Skin Ralphs on my Rovals by hand. They were a bit tight but that's a good thing. I enjoy their performance on loose over hardpack.ok, I've just put current model Ralph Snakeskins on current model Crest rims.
Everything that people say about these being a damn tight to fit are true. Unless you're superhuman it's a tyre lever job, but they will go on. TBH not that impressed because I'm not keen for a huge struggle by the side of the trail in the event of a puncture.
Finger crossed they loosen up a bit or it's a bit of a deal breaker for me no matter how good a tyre they are.
A positive though is that they inflated tubeles straight away with a floor pump. They were so tight I reckon you could probably even get them up with a hand pump.
Fit the valve stem first too, otherwise it's a PITA to get in once one bead is on.
Maybe I should swap sacrilege with stupid and clearly I am.That's called a raven with a tube in it.
Are the crests a larger ID than the previous ZTR offerings (e.g. Arch/355). The RK on my Arch went on pretty easily, and seated up with a floor pump. It is really important to make sure the bead you're trying to get on is in the central well, not sure if you were doing that or not.When I put my race kings on my Crests, I felt like I had just riden 6hrs.
