What tells you it’s a bubble? Hose could be a bit old and squishy.Haha nah go on. Can't sell used brakes with a bubble to a fellow burner now can I...
maybe, 3 year old hose? Sort of derailing, but it's productive hahaha. It's the front brake and the contact point is quite low - not quite to the bar, but noticably lower than the left/rear. Once at the contact point it feels firm. Its not the adjuster either I've played with that to death.What tells you it’s a bubble? Hose could be a bit old and squishy.
Yeah checked and they still got meat.Pads not flogged?
You bleed from top or bottom? Lever wound right out?Yeah checked and they still got meat.
Bottom up. I didn't realise there was a top down version. I also tried he leave the bike upside down and nothing changed (it usually goes to the bar when the bubbles move). Lever fully retracts right out. I do the epic bleed solutions method, but can give other methods a shot.You bleed from top or bottom? Lever wound right out?
Bottom up is right.... I’m just intrigued how you know it’s a bubble, when you can’t see it.Bottom up. I didn't realise there was a top down version. I also tried he leave the bike upside down and nothing changed (it usually goes to the bar when the bubbles move). Lever fully retracts right out. I do the epic bleed solutions method, but can give other methods a shot.
Does this work? I just received an order from bike discount. They had 1 litre Shimano brake fluid quite cheap. Got a bottle as I thought I’d give this method a go.Try this:
I don't, it's the only explanation I can muster and feels like most other times I have a bubble in there.Bottom up is right.... I’m just intrigued how you know it’s a bubble, when you can’t see it.
Hi Sethius,Any good LBS can you hook up on those ones, also had some hammerschmidt cranks left over dirt cheap. just giving you lads some heads up for those looking for that stuff.
Three pairs. 2 am, 1 FR. Price is absurd.. Any store should them cranks+ bb for 170 comfortably. I'd love to play and modify a set. IF one could make a narrow wide ring you'd be able to cut significant weight out of it, a machined 26t would be nice. Vyro might interest you too. System didn't get enough time with 1x taking over.. Reboot and ditch the boat anchor rear cassettes..Hi Sethius,
Prob too late, though have to ask...r the hammerschmidt still available?
Cheers
Clinton
18 years and it has only been ridden uphill!Potential project bike for someone in Melb
Or on flat ground...18 years and it has only been ridden uphill!
What did they do when they got to the top of the hill? Shuttle?18 years and it has only been ridden uphill!
